The difference is that the PropClip has a clip-like gadget and some spring loaded pins that make connection to 4 pads on the edge of a PC board while the PropPlug has a 4 position 0.1" header soldered to the same pads/holes as the spring loaded pins. Otherwise, the devices are identical.
The Protoboard can be used with either the PropClip or the PropPlug.
Now I understand! The PropCLIP is an actually clip on device. I'm using the USBSER and that takes soldering another 4-pin header onto the Protoboard.
"Everything in the world is purchased by labour; and our passions are the only causes of labor." -- David·Hume (1711-76)········
···················· Tropically,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
I concurr with paul, the plug works beautifully on the protoboard (as long as you have the LED's facing down that is)
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Paul Baker
