Parallax servo board — Parallax Forums
shaggydoshaggydo Posts: 1
edited 2007-07-09 06:58 in General Discussion
I'm using the Parallax servo board with vsa and I just go in a 7.5volt 1000ma power supply from this website. When I use more than one·servo at a time·It dramatically·boggs down all of them.·Has anybody else had this problem?
Restlessryan@aol.com
    edited 2007-07-04 02:16
    How are you powering the servos? From where do you get the + voltage?
    - Stephen
  • Capt. QuirkCapt. Quirk Posts: 872
    Look at your PAUSE statements within your code, if they are more than a couple Milli-Seconds total, you're· pause statements are the most likely cause.
    Also @ 7.5 volts, it's easy to grenade a servo.
