Fastest Serial Speed?
I just came over to the Propeller from the SX controller.
On the SX Controller, I was able to run Serial data (uart) at 1MB/s.
On the propeller, It seems that the fastest normal baudrate that I am able to run is at 115.2kB/s.
I have tried the FullDuplexSerial Object, and I have tried just using ·pin toggles in SPIN, but I am not able to get close to the Serial speed of the SX.
Is there something I am missing?·
Shaun
Shaun
I have some assembly SPI routines that are part of FemtoBasic that could easily be modified to transmit or receive half duplex asynchronous serial data at well over 1MBaud, probably closer to 2MBaud. Two cogs would get you full duplex at that rate.
Synchronous serial (SPI) can be done several times faster using one of the cog counters to generate the clock. Have a look at Rokicki's fast assembly low level driver for SD cards.
Post Edited (Mike Green) : 7/3/2007 5:51:58 PM GMT
I guess I was thinking that these instructions took the least amount of clock cycles. Are the cogs running at slower speeds than the system clock?
Sorry if I am asking questions that seem wierd...I just want to see about replacing the SX in my current system with the propeller with minimal re-design...I am working with technology that requires 750k Baud speed.
'Initialize line
DIRA[noparse][[/noparse]30]~~
OUTA[noparse][[/noparse]30]~~
'Add Start Bit
WAITCNT(CLKFREQ/ [noparse][[/noparse]bit-time] + CNT
'Add Data Byte - $AA
'Add Parity and stop Bit
can only transition pins at 12.5ns points unless you use the video circuitry with a PLL
which is very tricky). So 1MB sending should be easy; each bit is just two
instructions, a shift of a PHSA register to set an output bit and a waitcnt to wait a
bit period (you'd have to precompute the waitcnt values and they may not all be the
same width so you could get maximum accuracy).
Receiving is a *lot* trickier because you cannot afford to miss a start edge, and you
only have the stop bit period (and half of the last data bit period) to save out the
most recent byte somewhere and prepare to wait for the next start bit. 1.5 bit
periods at 1MHz is 1.5us which is 30 instructions which should make it possible.
For speeds that fast you'd need one cog for receiving and a separate cog for
sending since during any period you're sending, you'd miss the start bit (except
you *could* do tricks with counters to assess when the start bit actually occurred).
Heck, as a matter of fact, you could probably do some pretty amazing hacks
by just using a counter in increment-when-hi mode to monitor the stream and
then interpret the counts appropriately to locate the edges. Hmm.
Do you need fullduplex? Sending and receiving at the same time? It's the *async*
that gives the problem (you need to be prepared for a certain amount of
inaccuracy in the widths, and you need to be ready for that start bit at any time.)
'' Low level byte I/O spiSendByte mov i2cMask,#%10000000 :sendBit test i2cMask,i2cData wc andn outa,spiMaskClk ' Send data bytes MSB first muxc outa,spiMaskDI or outa,spiMaskClk shr i2cMask,#1 ' When mask shifted out, we're done tjnz i2cMask,#:sendBit or outa,spiMaskDI ' Leave DI in idle (high) state spiSendByte_ret ret spiRecvByte mov i2cMask,#%10000000 :recvBit andn outa,spiMaskClk ' Receive data bytes MSB first or outa,spiMaskClk ' Copy DO to data bit test spiMaskDO,ina wc muxc i2cData,i2cMask shr i2cMask,#1 ' When mask shifted out, we're done tjnz i2cMask,#:recvBit and i2cData,#%11111111 ' Eight bits received spiRecvByte_ret retThe transmit routine takes about 350ns per bit for the 8 data bits and clock. There's a bit more overhead calling these routines, fetching or storing the data itself, including parity / start / stop bits, etc. The overhead per bit in doing the clock would probably be about the same in doing the bit timing for the desired Baud.
Viewport v1.1, available here:
http://mydancebot.com/products/viewport/11
transfers data between pc host and propeller at 2Mbps using a single cog. The FTDI chip supports up to 3Mbps, but we were happy with 2, the next fastest setting. We are doing full duplex- data is typically sent from the Propeller to the PC for analysis, but data can also be sent the other direction (concurrently) to change memory values. It was not easy!
Hanno
