A simple application for parallel transmission between Popeller chips.
I want to have more than 8 cogs in order to simultaneously process more than 7 sensors; so, I have written a simple program that sends parallel data between two or more Propeller chips·using 9 pins. The below program· simulates two Propeller chips for demo purposes, but I am confident it will work with multiple Propeller chips. Also, I am just sending byte data, but in my application I will be sending longs using 4-byte transmissions. Also, I will need to distinguish which sensors/cogs in the second chip the data is coming from. That is easy also; just send a byte telling the receiver what to do with the next 4 bytes, etc. Note that a wait of (400 + cnt) from the time a receiver ready signal is sent until data can be sent is required. Maybe someone with better knowledge of timing issues can explain why the 400 minimum. Please look this over and give me any ideas for improvement you may have. I must keep it simple because this is a hobby and I won't use anything I don't understand.
Richard
Post Edited (RichardF) : 7/2/2007 9:20:01 PM GMT
Richard
acknowledge. The data strobe goes in the same direction as the data, and the acknowledge
goes the other way. You can either send data on both edges, or only on one edge, your
choice. This way you don't need any arbitrary waits, and you can speed up either end as
you want (usually by coding them into assembly). The usual signaling (four phase) is:
To do data on each edge, either you *always* send two bytes at a time
and you use something like this:
or else can just look at your own strobe to
determine what to do:
Perfect! Thanks.. and I understand it!
Richard
