DS1302 registers
Newzed
All of a sudden I'm having problems with the DS1302 setting and reading the time, but not advancing the time like it should.· Can anyone tell me how to access the seconds register?
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Setting it to a 1 would typically stop it. You want it to be zero, which it normally would if you’re setting it with correct data. I would recommend downloading the DS1302 Demo Code and set the DS1302 and see if it runs. It should update in the DEBIG window at that point. I hope this helps. Take care.
Do you know·how to set Bit 7 of the seconds register to 1?
Sid
Don't have VGA?
Newzed@aol.com
To set bit 7, you would do something like this:
secs.BIT7 = 1
GOSUB RTC_Out
Where RTC_Out is your write routine and you have already specified the register. Take care.
