Rotary Shaft Seals
I am using the motor from Jameco... http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=174692&pa=174692PS
in a centrifugal pump. Our biggest problem has been sealing the mechanical shaft. I can't use an O-ring, because they are not efficient enough and grind down rather quickly. I have heard about rotary shaft seals and lip seals, but they do not seem to be suited for such a small shaft diameter (.08 inches). If any of you could please help me with comming up with a good solution for this, I would be very grateful.
Thank you.
Thank you.
However, there are two problems to overcome: You're working with very small sizes, shaft-wise and, secondly, the seals will use up a large part of the power the motor can generate.
There are two common solutions: buy a motor/pump combination that has the seal built-in ( small bilge pump, laboratory pump, garden fountain pump, windshield washer pump,etc) or, do away with the need for a seal by coupling the motor to the pump with a magnetic coupling or by extending the motor shaft so its above the liquid level.
Cheers
Tom Sisk
http://www.siskconsult.com
If you're committed to the motor-with-seal direction, have a look at http://www.balseal.com/products/rotary.php. They have seals down to the size you will need.
You didn't say what the application was, but to get students to learn about centrifugal pumps, the long-shaft design noted above will let them design the pump without getting bogged down in finding a suitable seal.
Cheers,
Tom Sisk
John R.
Click here to see my Nomad Build Log
