Disconnected Prop Plug causing resets...
Got the Propeller DIP Plus Kit working with the Prop Plug... but I notice that when I disconnect the USB·link between the Plug·and the computer, the Plug causes periodic (every few seconds) resets.· Tried pulling the reset line high with a 10K resistor (guess???) but to no avail.
So, I'm yanking the prop plug from the breadboard instead of just disconnecting the USB cable... all works fine then.
The Plug doesn't get power from the board... so must get it from the USB source.· Hmmm....· Is one supposed to disconnect the entire plug instead of the USB connection?· Seems unlikely...
The Plug has no other problems from what I can tell.
Do I simply have a bad Plug? (beginning to seem that way...)
So we see this with Prop Plugs and PropSTICK-USBs... I imagine there might be quite a few folks out there experiencing this problem.
Thanks Phil.
-glenn
PropEd board, the power on led glows dimly.
