control a clippard solinoid valve in a car
i am trying to control a cylinder that will be powered by compressed Co2. the Co2 will be regulated to under 50 psi. i need to know how to power a clippard proportional valve (http://www.clippard.com/store/byo_electronic/byo_proportional_valves.asp). they can be powered 0-5, 0-10 and 0-20 volts. i am using a pic bs2 to trigger the valves but it will not have the amps to power it. do i us a transistor and power it with the cars battery. if so what kind. can i get the 0-10 volt valve and use some kind of voltage regulator to power it.
Without knowing all the details and specs of your project I would use the 0-20 solenoid to stay within the voltage range of your power supply that you intend to use. As far as switching the solenoid, a transistor or SSR in the current range of your load might be a good place to start. There is some helpful information regarding switching in the Process Control book, page 67. Also, more information about transistors can be found in the What's a MicroContoller Book, page 263. These are free downloads from the Parallax Web Site. Hope this helps with your project....
Twisted Pair....
