Sumbot 3.2 line sensor help fast!!!!!
HI, I own a sumobot and i am stuck.
Here is what is going on........ I have done the 3.1 sensor test and the test was successful.THE RX SIGN BLINKED THIS TIME.....the number i got for my sumobot on the black...was left-1643-1644
right-on black-1427-1428........White right- 71 left-77
I have attached both the codes...ALSO I CHECKED THE CONNECTIONS MANY TIMES! THEY ARE PERFECT........WHEN I DO THE 3.2 LINE SENSOR THE ROBOT DOESN'T MOVE A DANG BIT!!!!! WHAT DO I DO
HELP!!!
HELP!!!
Neither 3.1 nor 3.2 are supposed to move the 'bot. These are simply to test the sensor and demonstrate their function. Load up example 3.3 and it should go!
Jonathan
www.madlabs.info - Home of the Hydrogen Fuel Cell Robot
