Triac in control of 240V AC with 50Hz
Hi i met another problem and i brust my triac.· I need to run this operation silently so i can't use relay.· I configure the ciruit to a 100k resistor then to transistor (base) and gnd the emiiter·then to a switch which act like·a pin·of·bs2· and the input a 100k resistor and then to·the 240V and the output if the 240V is used to run the equipment.
When i power on the power supply the whole triac explo.... lucky i only use a switch to act like a stamp output if not my stamp will spoil.· Anyone have any idea how to control 240V AC without using a relay?
The link are the circuit i try to modify but i fail.....
http://www.nxp.com/acrobat_download/literature/9397/75015326.pdf
I think I know the connections you made, but the triac does not have emitter, base, collector. They are gate, MT1, MT2.
Or, Google "triac circuits" to get some basic circuits to work with.
Cheers,
Tom Sisk
http://www.siskconsult.com
1) The switch act as the out put of the stamp2
2) the signal is then sent to the transistor base
3) The emitter is connector to the gnd
4) The collector is connected to the triac·gate with a 100 ohm resistor
5) Terminal one of the triac are connected to the 240V AC
6) Terminal·two of the triac are connected to the output of the machine
So when i sent a signal from a switch which is configure to a 9v battery the 240v should turn on my machine right?· But instead the whole circuit was explo....
i hope this help when i write in point form.
From
Tony
-Martin
StampPlot - GUI and Plotting, and XBee Wireless Adapters
Southern Illinois University Carbondale, Electronic Systems Technologies
The first hit on Google turned up this safer circuit.
http://www.ee.washington.edu/circuit_archive/circuits/F_ASCII_Schem_PC.html#ASCIISCHEMPC_002
Cheers,
Tom Sisk
| 180 180 2.2k
> 120V
| 1| |6 | | Hot
| +=====+ | | MT1
| | MC | TRIAC | +-+
| | 3032| Driver | G | | TRIAC
\ 2| |4 | / +-+
2N3904 |----+ | | | | MT2
V \ | | |
| \ 43 .01u --- 10k / |
| / 500V --- \ |
+ | | | Neutral
+--+---o o--> 120V
/ load
(>-/\/\)--| 2N3904
V
The circuit it self is not rated 240v and also the the diagram is incomplete(i bracket it as where is it connect to 5v dc??) thx for your help thou.
From
Tony
- Stephen
Please stop and consider the danger of using an un-isolated SCR control scheme. This is not a wise move.
Take a look at this web page: http://www.teledynerelays.com/industrialcommercial.asp In it you will find many different solid state relays and motor controllers that cover a wide variety of power levels and voltages. For example, the LS Series: 30A to 600 VAC SIP SSR found here: http://www.teledynerelays.com/industrial/ls.asp will control 30A @ up to 600v single phase using a control voltage input level from 4v to 14v DC. This module requires a heat sink to be able to cover all its rated power levels.
Good luck!
Dan H...
I do not Know if you live in USA but if you do this might be what you are looking for Solid-State_Relay with a heat sink on it already i going to use one on my pool pump this weeken
http://web6.automationdirect.com/adc/Shopping/Catalog/Relays_-z-_Timers/Solid-State_Relays/AD-SSR225-DC
·I hope this will help you in want you want to do
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 6/29/2007 8:52:20 PM GMT
by the way i leave in singapore and the voltage here is 240VAC with 50HZ
Pls advise me
From
Tony
-Martin
