Problems with a usb PSC and a BS2P40
Capt. Quirk
My project uses a BS2p-40 and I have had no problem with using AUXIO so far, but I am unable to get my USB PSC to work within it's test program.
Both power sources are ok. The serial wire from my project is connected to Aux·pin 2. All 16 of the servo conections power up and holds a servo in place. There is a RED led and a flashing GREEN led. But there is no indication that the BS2p-40 program ever starts to loop.
thanks Bill
The "set buadrate" test works fine
thanks Bill
I believe that the value for·your Baud constant for 2400 baud, in your servo·test2.bsp file, is incorrect.
Your value of 396 is for a BS2 and not a BS2p.
The value for 2400 baud for a BS2p is 1021.
Just a thought.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
