embedded 802.11
All,
I have ordered a dev kit for the propeller because it is such an amazing chip at an amazing cost, and I have a rather lofty goal for it and dont really know where to get started. I would like to code a simple server on my computer that will transmit xml back and forth to the propeller chip wirelessly.
So here is what I know so far. I have an understanding of microcontrollers because I used to program the venerable 16f84 when I was in high school and college. I also have experience programming servers at a high level using sockets because I am a software developer, what I am missing is the enormous chunk of knowledge in between [noparse]:)[/noparse].
I guess I just need someone to give me an approach here, where do I begin? For instance, has someone already written a tcp/ip stack that will work on this chip? Is there any information on interfacing this chip with a pcmcia NIC? So far the best resource that I have come up with is a book called 'Implementing 802.11 with Microcontrollers' which is based on pic chips.
What is the best approach to getting xml wirelessly transmitted to this chip, or is this simply too much to ask of this chip?
Thanks in Advance,
Dorian
Thanks in Advance,
Dorian
There hasn't been many attempts at writing a tcp stack for the Propeller. I have written a very poor implementation of a enc28j60 ethernet chip driver + tcp 'stack' that supported udp send/receive, ping, arp reply/request, and a one packet http server (that also supported base64 decode for http authentication). The largest issue I encountered is that spin is a bit slow, which means there was a delay on how fast I could pump out packets and handle them. A 32byte ping required about 40ms round trip over 25 feet of cat5 cable and one switch. I am sure it's my poor coding since spin can't be that bad, but I simply don't have time to try to get it to work any better since I only needed to host a webpage with 8 buttons to control 8 devices.
I can give you a copy of my source via PM if you would like it. I don't post it on the forums because I don't want it to be used in commercial purposes without being asked (hey, it took me 4 weeks to get working well). What I would really like is to start a Google Code project and have people help correctly implement the tcp stack.
Harrison
Post Edited (Harrison.) : 6/28/2007 2:02:47 AM GMT
Paul Baker
Post Edited (Paul Baker (Parallax)) : 6/28/2007 6:18:40 PM GMT
TCP/IP presents other challanges, but uIP is probably a reasonable starting point. However, I don't require TCP/IP for my application.
It's not all that hard to count the number of grains of sand on the beach. The hardest part is making a start - after that it just takes time.·· Mirror - 15 May 2007
You had asked about 2mm connector parts for the WiPort. I found some on Digikey for this same purpose. In the Digikey catalog, they're under "Vector Specialty prototyping
boards," built by Vector Electronics & Technology, Inc.. There are four 2mm boards available: V1253-ND, V1254-ND, V1255-ND, and V1256-ND. The V1253-ND is strictly 2mm spacing, and the other three are combination inch-mm.
Jim C
