optional reset and power switch, for project boards.
I don't know why I haven't use projects boards sooner! they are a dream compared to the trying to do a project on a Radio Shack experiment board! I have one suggestion for you (parallax) though. Would it be possible to add holes in the PCB, so that in the future and if desired a 2 pin SIP header could be added for both the reset and the power switch. this would allow a project board to be put in an enclosure and have the ability to mount buttons on the enclosure. I can't think of any down side to this other than if the switch mounted on the board was on it would override the external switch but I don't see that as a huge issue. Just a thought!
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
