Digital RGB Interface for LCD
Many RGB (full colour) LCD displays have a digital RGB interface that uses Hsync Vsync and Dot (pixel) clock.
- this looks to be directly compatible with the Prop outputs
BUT can you route the Dot Clock signal out from the Propeller Chip ?
This signal is not needed with analog RGB
Anybody tried this interface yet - or know how to get at the PLL dot clock signal?
_______________________________________
A Little Bit Of Knowledge Is A Dangerous Thing
But How Do you Know What You Don't Know?
I have tried to use that code but was not able to get the display to work 100%. The issue was that I was not able to obtain a correct datasheet for my display, along with my limited knowledge of how to calculate the backporch, frontporch, line timings, etc. I used formulas provided in a Sharp appnote, but it didn't seem to help me fix my display problems. I ended up with a display that only took up 1/4 of my 9" screen that had slight noise and flickering (obviously incorrect timing).
Harrison
Paul Baker
Any Thoughts on this one:
Use additional cogs to increase the VGA colour depth - ie one outputs bits 0-1 the next is for bits 2- 3 etc
- wouldn't need a an R2R ladder of resistors as this is for the above mentioned digital LCD interface.
Assuming all the params. are equal - would this work?
I would really like to achieve full 18bit colour for our robot eyes application -
see www.robothespian.co.uk
Paul Baker
