Graphics_Demo — Parallax Forums
Graphics_Demo
lilbowserlilbowser Posts: 2
edited 2007-06-27 08:18 in Propeller 1
I am having a rather odd problem with Graphics_Demo.
Even thogh the color works fine in Graphics_Palette I can not get it to display color in Graphics_Demo.
Any help would be appreciated thank you.
    edited 2007-06-27 03:51
    Graphics_Palette just tells you what value you need to produce a particular color on the display. The actual choice of a color is a two step process. Each pixel can have one of 4 colors chosen from a palette. The display is organized into 16x16 tiles of pixels and each tile can have a different palette. There's an array of palettes (called colors) each entry of which consists of a long word and the 4 bytes of the long word contain the color information (from Graphics_Palette) for one of the 4 colors. I'm not sure, but I think that Graphics_Demo uses colors[noparse][[/noparse] 0 ] for all of the tiles. Try changing colors[noparse][[/noparse] 0 ] to some different value after the initialization routine (where it says 'init colors).
  • lilbowserlilbowser Posts: 2
    edited 2007-06-27 04:20
    This is what was there
    'init colors
      repeat i from 0 to 63
        colors[i] := $00001010 * (i+4) & $F + $2B060C02[/i]
    edited 2007-06-27 04:35
    Yes, I know. It looks like the 64 color palettes are initialized with one color code = $2B, another = $06. The third color varies from $4C, $5C, ... , $FC, $0C, ... $3C repeated every 16 palette entries and the fourth similarly varies from $42, $52, ... , $F2, $02, ... $32. Look at Graphics_Palette for the colors that match these values.
  • rsumrsum Posts: 2
    Its not an ntsc/pal issue?
