Some problems about connecting a screen with multiple connections to the propel
I would like to connect a screen with multiple connections to the propeller.
It has a normal RS232 connection and a "General Port Connector". In the pdf with specifications following thing is written about the "General Port Connector":
This connector enables you to connect the second RS232 port (5 Volt signals only, no standard RS232
signal level of ± 9 Volt), the I2C, and some other signals described below.
And following are the most relevant parts from the electrical specifations table
I must say I have absolutely no idea with wich of the to ports i need to connect it and also If and wich resistors should be user?
Also with the "General Port Connector" it is possible to use I²C. Is this preffered or not. I never used I²C and don't know anything about it.
It needs 3 connectors in according to the specifications of the screen:
Could anyone give me more information about this? (=I²C and what to chose)
Thanks in advance
Item Symbol Condition Min. Typ. Max. Unit Supply Voltage VCC - 4.75 5.0 5.25 V RS-232 Input Voltage Operating Range ±30 V RS-232 Input Threshold Low VIRL VCC = 5V 0.8 1.3 V RS-232 Input Threshold High VIRH VCC = 5V 1.8 2.4 V RS-232 Input Hysteresis VIRH VCC = 5V 0.2 0.5 1 V
- I2C Data (witch has to be pulled high, according to this specification)
- I2C Clock (Don't have an idea for what, i don't believe RS232 has this?)
- I2C Alert – signals unexpected data to be sent to the application (e.g. a keystroke) (is this a normal I²C line?)
Thanks in advance
Looks like your screen is a +5v screen - so put 1k resistors on the serial between the prop and the screen and it will be fine. With the i2c follow the i2cDemoApp.spin documentation.
Cheers,
james
