ultrasonic sensor
how can i attach an ultrasonic sensor to a sumo bot the bread board is facing to the right/left so if i attach the US sensor to the bread board it will face the wrong direction but if i place it forward it'll short circuit i know the boe-bot faces forward but if i can get the US to work the way i want could i use 2 US sensors at the same time or would it read the wrong sound frequency
http://www.parallax.com/detail.asp?product_id=805-00012
·Yes, you can use more than one Ping))) sensor on the same robot,·but put a pause in between·their triggers so·they don't pick up each other's echoes.·20ms should be·plenty, it might not be a problem·if they are facing opposite directions depending on the environment.
The Stamps in Class book Smart Sensors is a free download and has a couple of chapters about the Ping)))
http://www.parallax.com/detail.asp?product_id=28029
Stephanie Lindsay
Editor, Parallax Inc.
D Faust
