Current question
I have a power suplly board that can give me 12V and 3A.· I know that the max voltage i can have in stamp is 9v right?· As for Current is only a few mA.· I know how to slove the Voltage problem by using a voltage divider circuit as voltage is different in series but how about the current? i mean how can i reduce the amphere from 3A to a few mA that is needed by the board.· Pls advise as i do not want to damage my new stamp board thank.
From
Tony
From
Tony
- Stephen
2) Your question about using 12V doesn't have a simple answer. The BS2 itself can handle higher voltages than 9V, but the excess voltage is turned into heat that its regulator has to dissipate. The more current the BS2 has to use (like to drive LEDs or other loads), the more power has to be dissipated. Eventually, the regulator will shut itself off to protect itself and the BS2 won't work until the regulator cools down. Some boards that the BS2 might be plugged into may have their own input voltage limitations (like the development boards). The best thing to do is to have a separate 7.5-9V regulator (like an LM7808 or LM7809) with its own filter capacitors as described in their datasheet to drop the power supply voltage to 8 or 9V and distribute the heat dissipation.
So you can't "over-current" your BS2, it only gets the current it needs. Now you CAN "over-voltage" your BS2 -- but 12 volts is not an "over-voltage", so that's ok too.
Another analogy is like a water tower. The height of the tower is the 'voltage'. The size of the pipe leaving the tower limits the amount of water ('current') that can leave the tower. If you attach that pipe to a thin hose to water your lawn, it doesn't matter that the tower has LOTS of water in it, the thin hose will only 'conduct' a small amount of water.
Now, if you apply too much pressure ('voltage') to that thin hose, you can blow it out. But as I say, with 12 volts, you're not applying too much voltage, and so the BS2 will only take as much current as it needs.
Quattro
'Necessity is the mother of invention'
