Stereo headphones and the ProtoBoard? — Parallax Forums
simonlsimonl Posts: 866
edited 2007-06-27 08:16 in Propeller 1
Hi All,
I'd like to output sound (starting with Chip's excellent demos) form a ProtoBoard, but am having trouble finding a suitable stereo amp.
Has anyone else managed to output stereo sound to headphones? What did you use?
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style smile.gif
  • LeonLeon Posts: 7,620
    edited 2007-06-26 10:43
    I tried the software on my home-made board, putting the output into the line input on my DAB radio. It sounded quite good.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • simonlsimonl Posts: 866
    edited 2007-06-26 10:52
    Hi Leon,
    Thanks for the reply.
    So, you just took wires from the two prop' pins to a plug, and placed that into line-in on the DAB?
    Cheers,
    Simon
    edited 2007-06-26 12:08
    Yes, that's basically it. I had the RC filter circuit as used on the demo board on my board, on the output pins. I had the radio set to to audio input. I often use it if I need an audio amplifier for test purposes.
    Leon
  • parts-man73parts-man73 Posts: 830
    edited 2007-06-26 12:21
    I've soldered a few caps and resistors to my Protoboard, along with a stereo jack. I've used Paul's example from this thread - http://forums.parallax.com/showthread.php?p=606294 duplicated for each sound pin (P10+P11)
    Then I just use the amplified speakers from my computer. It works very well.
    Brian Meade
    "They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
    edited 2007-06-26 14:17
    Hmmm, so I could do something like the following then?:
    Pin 10 (R) --- 200Ω ---- 10µF ------------------+
                       0.1µF          | JACK  |   |   |  >
                        GND --------------------+      |
    Pin 11 (L) --- 200Ω ---- 10µF ---------------------+
    The stereo jack would then plug into the line-in on my PC?
    Cheers,
    Simon
    edited 2007-06-26 15:04
    yep
    edited 2007-06-26 15:27
    one minor correction - you need to add a 0.1 uF cap between gnd and the junction of the 200 ohm resister and the 10 uF cap for pin 11 also.
    Instead of plugging into the "line-in" jack on the computer. I just unplug the speakers from my computer and plug the speakers into the jack on the protoboard. Most computer speakers have a built in amplifier anyhow.
    Brian Meade
    edited 2007-06-26 15:29
    good catch, yes the circuits for each channel should be the same.
    Graham
    Brian / Graham; many thanks.
    Cheers,
    Simon
