backup battery
I haven't seen any schematics for a backup battery for microcontrollers. Say if you are keeping time with your propeller, you wouldn't want that data being erased, when a blackout occured. How do you implement a backup battery like that?
circuit and charge the battery when it lows from the charge voltage .but in turkey these ic hard to find.I m thinking abaut that
propeller can measure voltage with adc and can decide abaout charge
How long would you need to hold power to the prop?
It was suggest for a project I am working on to use a super cap. You could use a 4.7F cap which should keep the power up for a while.
I dont believe you'd need any additional circuitry for this either.
Of course, this wouldn't hold power up for hours, rather a number of minutes.
But attention, not all are rated for 5 V some are only for 2,5 V !
Post Edited (deSilva) : 6/26/2007 10:11:21 PM GMT
one cog of propeller check voltage of battery and when its below the charge voltage statrt the charge
http://www.sparkfun.com/commerce/product_info.php?products_id=99
Im using something which I think is similar in my rocket controller.
I have 2 batterys and a big cap.
The prop can draw from both batteries while running(or 1 if only 1 is installed). When the high current pyro's fire, they can only draw from the main battery and the prop still runs off the 2nd battery. This prevent brownout's.
Only problem is, both the main and secondary battery need to be the same voltage as they are in parallel.
I will post the schematic when I get home if your interested?
