12Volt-batterie convert to 9volts for the Propeller-Chips
Ref: 12Volt-batterie convert to 9volts for the Propeller-Chips
hi
i build a 4 Leg-Bot with 12 servos.
with a 12volt 3.7AH-Batterie
the servos takes 6volt
i convert the 12 volts down to
- 6 volt with a L7806 for the servos
- 5 volt with a L7805 for digital devices
- 9 volt with a L7809 for 3 propeller-chips (PropStickUSB)
now the question:
is this possible for the propeller-chips without dammage???
i ask you before i testing the stuff
thanks for your answers
regards
nomad
hi
now the question:
regards
nomad
·in the stickies at the begining of the forum...
·cheers Dennis
http://people.delphiforums.com/cocokiwi/Image/picture.jpg
cf www.national.com/pf/LM/LM2937.html e.g.
The regulator will become warm of course when directly connected to the 12 V batteries..
I myself would connect the PropSticks to your stablilzed 5V system
Post Edited (deSilva) : 6/24/2007 10:48:00 AM GMT
thanks for your answers.
is this correct:
1) i can connect my 12volt, 3.7AH Batterie directly with the PowerSupply of the
propeller-chip without the L7809 IC
2) connect my 12 volt batterie with the L7809 IC,
the attachment shows the 2 stuffs (powerSupply.JPG)
excuse my bad english
many thanks for your answers
regards
nomad
You can attach the PropStick directly to the 12V battery, but it's not good design. You are wasting a lot of power by using linear regulators which convert the excess voltage into heat. I would strongly suggest you use a switching regulator to reduce the battery voltage (which can go as high as 13-14V with a fresh charge). The best setup would use two switching regulators, one to supply 6V directly to the servos and the other to supply 5V directly to the logic and the PropSticks. Several manufacturers (including Texas Instruments) make small hybrid switching regulators designed to directly replace linear regulators.
I'd be careful about the servo supply. Most servos can draw over 1A under load and most of the linear regulators won't supply over 1A.
12V battery regulated to 6V 1A servo .. Say it has 14volts (as they do while full)
14 - 6 V leads to 8V voltage drop at regulator.. With 1A it generates 8Watts Heat (+ some extra on regulator losses). So in the end you'll end up wasting over half of watts your Battery has due inefficient power regulation.
This will also help stabilize your digital 5V system you talked about, and to connect the Propeller to it is "Solution 3" you did not sketch. And don't take "... 6 to 9 V..." too serious; the regulator on the PropStick will well work between 15 and 4,5 V (see datasheet link)
7,2 V (starting near 8 and staying always above 6 V) is an excellent behaviour for digital logic...
thank you verry much for your help
i have a question:
i am not a electronic geek, and to buy the switching regulators, at my distributor
can i have a discription of this switching regulators
you write:
< (including Texas Instruments) make small hybrid switching regulators designed to directly replace linear regulators.>
to deSilva, thanks but for the first tests, i make this with externBatteries.
thank you for your answers
regards
nomad
thanks for your answer,
today i am looking for this stuff at my distributor.
regards
nomad
