Which IR detector in PE kit? — Parallax Forums
RichardFRichardF Posts: 168
edited 2007-06-23 14:22 in Propeller 1
The IR detectors that came with my PE kit have no ID nor were there any parts lists indicating the mfg part number. The BOE robot manual·shows an IR detector that has the center lead grounded (again no ID as to type). The soon to be published PE kit counters lab manual has the IR detector as a·PNA4602 with the center lead as the output.·Could someone tell me which·IR detector came in my PE kit? The detector has a squre metal case with·four windows on the front·.
Richard
  • parts-man73parts-man73 Posts: 830
    edited 2007-06-22 13:02
    Richard,
    Look at this thread, it has a list of the entire contents of the PE kit.
    http://forums.parallax.com/showthread.php?p=639062
    Brian Meade
    "They who dream by day are cognizant of many things which escape those who dream only by night" - Edgar Poe
  • edited 2007-06-22 23:05
    Richard,
    The IR detector is equivalent to the PNA4602M. You're right about Figure 11, ground should be in the middle and signal on the bottom. I'll add that to the revision list along with pin numbers. Updated doc should be ready next week.
    Andy
    Andy Lindsay
    Education Department
  • RichardFRichardF Posts: 168
    Figure 14 also.
