Coding problems !!!!!!!
Does anyone have the code for the whiskers, the Ir sensor for falling off a table and the following a flashlight code? They work individually for me but i need them to work at the same time. Can anyone do this I am terrible at coding ? I can even send you the codes I have now
thanks
Marcellaj@wit.edu
thanks
Marcellaj@wit.edu
- Stephen
so much
Please check the pulseleft / pulseright numbers when left of right IR = 1.
These should not be 0 !! Nor should be the pulsecount.
Check the manual again.
Ed
We worked together and compiled some code for·the Boebot with IR detection to prevent the
BB falling from the stairs or table .. or fall in a hole !!
At the same time the photoresitors are used to follow the flashlight.
Here the code, mainly copied from the textbooks and a video the proof it works .. more or less...
http://www.youtube.com/watch?v=C6UijDGAmqs
Ed
Post Edited (Skywalker49) : 7/13/2007 7:24:52 AM GMT
