lots of Inputs??
Hello, i have been looking into these chips and doing some research for some time but i have not found any details on the following few points if someone can fill me in as i am currently doing research to provide a computerisation for an industrial saw and require some measurement readings etc...
- Approx 10-15 analog inputs, 0-5v and at least one 0-24v line
- Approx 10-15 Digital outputs for relays
- VGA/TV monitor + keyboard to manipulate the saw
- SD reader/writer to read in settings and write out a log/counter for statistics later
- Bluetooth/RF to control the saw or send info back to a computer
could someone please maybe suggest some ways that the 8 lines could utilise such equipment and if it is possible to have this many peripherals hanging off the propeller chip. thanks.
24 Analog Inputs - 0-5v - 12 bits
8 Digital Inputs
8 Digital Outputs
10Mbps Ethernet Chip
SD Interface
3 Bi-directional serial ports
Real time clock with extra RAM and battery backup
32K of extra EEPROM
So what you want doesn't seem to be a huge challange, but not easily done with the demoboard as is - you would have to add quite a bit of multiplexing to those 8 pins.
It's not all that hard to count the number of grains of sand on the beach. The hardest part is making a start - after that it just takes time.·· Mirror - 15 May 2007
What kind of a saw is this?
Graham
What are the analogue inputs for? Are you just wanting to be able to display the values or act on them?
Graham
Like oRiCLe, I am also putting together a couple of projects with lots of ADCs.
Some MCP3208 serial 12 bit 8 channel ADCs.
Some ADS1271 serial 24 bit 1 channel ADCs.
I originally thought I needed lots of CPUs.
But I suspect I can daisy-chain the serial ADCs into several chains,
then feed several chains into independent SPI ports on one propeller.
My questions about speed were answered at
http://propeller.wikispaces.com/interface
Thank you for telling me about the TPIC6595 8-Bit Shift Register, 0.25 Amp output.
It will probably replace a 74HC595 eight bit shift register, plus an array of transistors, in one of my designs.
( http://opencircuits.com/POV_display ).
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! The average PC while browsing the internet typically uses less than 30% of it's potential, why not donate a portion of the rest for cancer resaerch?
