uMP3 Test Program
Guido
Can someone put me in the direction for the uMP3 Test program that adjust the Volume etc from the Debugin on the Stamp Editor' I had it now I can't find it!
Guido
Guido
If you use the Google Parallax search for uMP3, you come up with these results:
http://search.parallax.com/search?client=parallax&site=parallax&output=xml_no_dtd&proxystylesheet=parallax&ie=&oe=&as_q=uMP3&num=10&btnG=Google+Search&as_epq=&as_oq=&as_eq=&lr=&as_occt=any&as_dt=i&as_sitesearch=&sort=&as_lq=
There is a link there·to·an article from Nuts & Volts that Jon Williams wrote, that should be a big help.
Tim
I don't know if this is what you're looking for, but I posted my BSII to uMP3 test code here:
http://www.spiderspreyground.com/howto/ump3/
You can also have a look at the rogue robotics forums, though they're not nearly as active as these [noparse]:)[/noparse]
http://www.roguerobotics.com/forum/41
Hope this helps [noparse]:)[/noparse]
Vern
