hydra can't be programed
·what started out as a minor problem has turned into a major one . About a mounth ago I noticed that is was taking more than one try load the eeprom with a program . First it took 2 times and then 4 and so on ,now I can't get it to load at all . I've tried a differnt propeller chip , eeprom and even tried to program it with the usb2ser port with no luck .Also I tried a differnt computer and that·won't work either .I can still program my demo board and devopment boards but have no luck with the hydra.
Thank's Brian
www.truckwiz.com
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website ( Bet you can't guess why)
Thank's Brian
www.truckwiz.com
What version of the propeller tool are you using?
Also, try plugging in the 128K card and programming that. It might be a cold solder joint on one of the lines around the eeprom and or programming lines, or some debris.
Where did you buy the HYDRA?
Andre'
It seems that one of the few things that's screwed up in the design of the Propeller is the system for programming it. Serial transfer should be way more resilient than this.
So it was a timing thing. Specifically, I had the amount of time it took for Baggars program to begin to do it's thing. Loading an extremely short program, right after powerup did the trick.
I've also encountered modes where it takes a few attempts back to back in order to program the HYDRA. This does not occur on the demo board I have. So far, it's only been two, perhaps three. I just leave HYDRA on, make sure things are connected, and hit F10 a coupla three times.
·prop tool version 1.0 , bought my hydra from parallax (was one of the first ones). tried expansion card too , didn't work. tried a new 5.00 crystal (don't have any other ·10.0 besides the one that came with the hydra). lights are on nobodys home.
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 6/20/2007 2:32:30 AM GMT
·tried new propeller tool , still won't work
Thank's Brian
www.truckwiz.com
I would say control all the lines ^_^
Because I had some problems too because of that.
A really sad story for my hydra
Post Edited (Hallomann) : 6/20/2007 12:26:53 PM GMT
Being that your giving me so help trying to figure out whats wrong here, I'm shipping the hydra back to parallax and you can play with it until your hearts content.
Thank's Brian
www.truckwiz.com
Thank's Brian
www.truckwiz.com
Post Edited (Brian Beckius) : 6/21/2007 4:25:21 AM GMT
"andre',
Being that your giving me so help trying to figure out whats wrong here, I'm shipping the hydra back to parallax and you can play with it until your hearts content."
But, looks like you got it from Parallax, so let's see what they say about it. But, you previous 2 posts directed at me seem off base, I AM trying to help you.. So I am not sure why you are writing with the tone that you're writing?
Andre'
Sorry for being such a smart ### , I called parallax and told them I was shipping it back , they told me to ask you . I know the problem is terminal , I just get sick of jumping through the hoops.
Thank's Brian
www.truckwiz.com
Andre'
·Here's where we are sitting·. Parallax says the chip is bad, I change the chip with a extra one that I had. Is it possible that there is somthing on the hydra that is messing with the propeller ?
Thank's Brian
www.truckwiz.com
How about sorting this out via private messages or email, and summarise the thread when the problem's been sorted. The rest of us forum members can't really help you out at this stage.
Post Edited (CardboardGuru) : 6/28/2007 1:17:49 PM GMT
I don’t only use the propeller in my hobby ,I use it in my business .Tech support always tells me to post my problem. I can not tell you how frustrated I get when I can not tell you the real problem because it messes with what I’m trying to build without anybody knowing .
Thank's Brian
www.truckwiz.com
shipping is caught between old address ane new address . I'm just going to leave it at that!
Thank's Brian
www.truckwiz.com
Anything is possible. I thought you sent them back the HYDRA board for replacement? How did they diagnose that the propeller was bad? Anyway, the board is pretty simple, the only things that can be wrong are a bad chip (the propeller or the USB chip), missing part, or a bad solder joint really. Bottom line, just request a replacement HYDRA board, problem solved. And I am not sure what you are referring to about shipping, but if you have a mail foward then it should be no problem. USPS will forward mail. Usually parallax uses UPS which might leave a package at your old address since they won't have a foward, so all you do is get the UPS tracking # and call UPS and tell them the package was left at your old house, or just drive there and pick it up.
Anyway, I thought you had got a replacement hydra board from parallax, so where are you now on this?
Andre'
I'm a busy person just like yourself ,I do not think that the prop chip was bad. Tech support drives me up the wall. I tried everything under the sun to get my hydra to work, I marked my board and chips so that I would know what I'm getting back. I don't have problems very often and I always look at the post for like problems. I sent the Hydra 2 weeks ago next day air to tech support . It took 6 days and then I had to call to find out that they thought the prop was bad (if that is the case ,I'm sitting on a whole lot of bad chips!).In the note I sent with the hydra I made sure to tell them after July 1 I would have a new address, so they shipped june 28 on UPS with 3 day delivery. Lets see June 28 + 3 days = July 2 (First delivery day). So now I have a package that is just rolling around in the UPS system.
Thank's Brian
www.truckwiz.com
Anyway, let's hope the UPS gets to you and everything is fixed up. I think you had two things working against you; parallax just did an inventory, plus it was a holiday this week, which tends to thin out the workers since many go on vacation during this time (or last week, and man power might be thin).
Andre'
Paul Baker
Post Edited (Paul Baker (Parallax)) : 7/6/2007 11:54:59 PM GMT
epmoyer has found a solution.
http://forums.parallax.com/showthread.php?p=660221
AndreL I would recommend you have a look at this post.
Check out my robot using the propeller robot.tmcp.com.au
If you offer cheap PCB fabrication, perl programming or any other helpful services please email me at.
anthonybmyatt@yahoo.com.au
For some reason, for the past week or so, when I attempt to program the Hydra, it will reset partially through the transfer and run whatever I had programmed to EEPROM.
The size of the transfer did not matter. Small or large, it would not transfer.
Drove me nuts. I tried the latest Propeller Tool, version 1.05.5 and it install newer drivers but that did not help. I even tried reverting back to the USB2SER key and that had the same issue.
I finally decided to turn off window's spy checker software and it started working again. Adding the tool to the safe list did not help any. I could not find anyway to tell it the driver was safe..
So, when I forget to turn of the spy checker I cannot program the Hydra.
I can duplicate this all I want just by enabling and disabling that security program.
I guess in one of the recent many windows patches, it screwed with the security of the serial/usb ports/drivers.
Hope this helps some,
Bob Woodring
Just got a new T60p Lenovo laptop. It works with my HYDRA and Demo board without a hitch. The other machine was a Dell Inspiron 8600.
Notably, some portable disks were an issue with that particular laptop as well. I had to be careful when I connected the disk, or it would just hang, spinning up over and over.
The demo board worked on either one with no problems. Still considering the EPMoyer mod...
