Quick question about Parallax SX28 Protoboard. — Parallax Forums
RobotWorkshopRobotWorkshop Posts: 2,307
edited 2007-06-19 01:31 in General Discussion
Hello,
As most of you are probably aware, the pinout for pins 1-14 on the SX28 chip are different on the surface mount and DIP versions.
I just took a closer look at the SX28 Protoboard and it appears that the pads for the 28-pin DIP (w/wider spacing) match up with a regular 28-pin ZIF socket and also the DIP version of the chip.
So, I should be able to unsolder that surface mount SX28 chip, mount my ZIF socket in it's place, and have a nice way to pre-program the SX28 DIP chips.
Has anyone else tried this?
Robert
  • JonnyMacJonnyMac Posts: 9,799
    I have a board that was built like that (with a ZIP socket); part of the original group of SX28 proto board prototypes -- it works fine.
