controlling pulley speed with Basic Stamp Module
I have a 5HP Briggs/Stranton gas engine....Attached to the drive shaft of this engine·is a pulley system. The system is set up as a·simple winch.
The speed·[noparse][[/noparse]RPM] of the pulley is controlled by a manual·post attached physically to the throttle lever on the Briggs/Stranton engine which can increase or decrease engine speed by changing the·post position. [noparse][[/noparse]varying RPM of pulley]
I would like to set·up the·Basic Stamp Module·to monitor the RPM of the pulley and bring it up to a pre-programmed rate. I am assuming I will need a solenoid physically attached to the throttle of the Briggs/Stranton engine which·can then change engine speed based on feedback from the measured RPM's of the pulley. I am assuming the Stamp Mod can measure RPM's, will it also be able to be programmed to vary the positioning of the solenoid and provide for an accurate pre-programmed pulley speed?
Any help would be greatly appreciated. Thanks to all in advance.
jz
jz
edited for typo (missing r in servo)
Post Edited (skylight) : 6/18/2007 10:30:11 PM GMT
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
Ken Gracey used a servo on the throttle of a gas engine, plus he hooked up a pin to the magneto so the chip could "kill" the engine (i.e. turn it off).
For counting RPMs you will probably need to use a chip like the SX -- the Stamp will not be fast enough.
p.s. -- actually, if you put sensors on the PULLEY rather than the engine itself, you might be OK with a Stamp -- depends on how fast the pulley will turn.
