Can you develop on the Hydra then port to the Propeller Proto board?
Would it be difficult to port a prog written for the·Hydra to one of the·the Propeller Proto boards?
What would I need to do that?
Thanks.
Thanks.
If you want a TV output from a Protoboard, you'll have to add your own resistors and a socket for the video cable. You'll have to do the same for audio if you want that ... just copy the circuitry in the Hydra manual. Similarly, if you want to use a Hydra expansion card, you'll have to add an appropriate socket to the Protoboard.
So there will have to be some small changes in hardware, resistors, sockets, crystals, and drivers (if using mouse).
So, with those changes made (above) the same prog written for the Hydra could be downloaded into the Propeller chip? Would I have to add extra memory to the Propeller chip?
Please keep in mind that the Hydra is a Propeller with some specific I/O devices attached and the Propeller chip is doing most of the I/O. All of the I/O devices consist generally of a few passive components and the appropriate sockets for connection. The primary advantage of buying a Hydra is that you get a well made board at a price that you can't duplicate doing it yourself and you get the Hydra manual (with its CD) which is well written, very thorough, and with plenty of examples. Its focus is on gaming, but there's plenty on Spin and assembly and some of the video information is not available elsewhere.
Tony A
