Boe-bot servo tuning...
Hello all...
Calibrating my servos, the boe-bot will go straight with the settings 650 and 810. The book mentions that if the servos are 'severely' mismatched, then it'd be that kind of adjustment. Before I continue, should I go back to hardware tuning or continue with that much of a difference?
Thanks!
OSOK
Thanks!
OSOK
D Faust
- Stephen
D Faust
Thanks again!
Your servos are fine, no need to worry. The 850 and 650 values are outside the the range of linear speed control. So, for a large change in pulse duration, like 850 to 810, there won't be that much of a change in speed. So your speed adjustment was actually pretty small.
It's only when you get in the 700 to 800 PULSOUT Duratoin range that the pulse duration starts looking proportional to speed control. Check out the graph on page 115 of Robotics with the Boe-Bot. Speed control vs. pulse duration is mostly between 1.4 and 1.6 ms pulses, which translates to PULSOUT pin, 700 to PULSOUT pin, 800.
Given that 810 straigtened out the Boe-Bot's forward motion, you'll probably see very similar graphs for the left and right servos when you try Chapter 3, Activity #4.
Andy
Andy Lindsay
Education Department
Thanks again!
Thanks OSOK!
Andy
Andy Lindsay
