pulsout on a bs1
I have working BS2sx code for a servo (HS-303), pulsout at 2250 centers the servo. I want to get the servo to work on a bs1
my manual says that the bs1 pulsout command is in 10μs units. and the bs2 is in 2μs units, so 2250x2 = 4500 / 10 = 450.
450 doesn't center the servo. no matter what I send to the servo it is out of range and turns the servo counter clockwise. to it's limit.
any thoughts? I usually just guess a couple of times to get in the right rang and then fine tune it to get the limits. but I can't seem to find anything in the working range.
any help would be appreciated.
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
