Detecting a collision with the MX2125 — Parallax Forums
MightorMightor Posts: 338
edited 2008-08-18 18:42 in Learn with BlocklyProp
Hi there,
I am trying to equip my bot with the MX2125 setup as a collision detector, rather than a series of microswitches or IR detectors. I copied and tweaked a program from the Smart Sensors book to do some data logging so I could see what it looked like if I bumped the bot as it stood stationary on my desk.
This is the program I used:
'{$STAMP BS2}
'{$PBASIC 2.5}
total CON 240
x VAR Word
y VAR Word
index VAR Word
FREQOUT 1, 50, 4500
FOR index = 0 TO total STEP 4
  PULSIN 6, 1, x
  PULSIN 7, 1, y
  x = (x MIN 1875 MAX 3125) - 2500
  y = (y MIN 1875 MAX 3125) - 2500
  WRITE index, Word x, Word y
  PAUSE 100
NEXT
FREQOUT 1, 50, 4500
  READ index, Word x, Word y
  DEBUG SDEC4 x, " ", SDEC4 y, CR
NEXT
It produced the graph as attached to this post. You can clearly see the spikes from when I tapped the front of the bot but note the mirrored spikes, about 2/3rd of the way. That's when I tapped the left front corner of the bot.
Now what I'd like to do is somehow use this data that I am logging to detect when the bot bumps into something. I can calculate the direction the bump was coming from using the data from the MX2125. However, I am not sure how I would discern between the bot going up a ramp or hitting something. Are there algorithms out there that can detect this kind of thing? Basically I need something that can detect spikes but will leave gradual increases alone. Does anyone have any ideas how this could be implemented?
Mightor
| What the world needs is more geniuses with humility, there are so few of us left.
781 x 387 - 15K
    edited 2007-06-17 13:52
    I think your bigger problem will be the vibrations of just normal movement. The bot will be shaking more than you expect. I would stay with other forms of object avoidance. Remember the idea is NOT to run into other objects (it's bad manners)
    - Stephen
  • MightorMightor Posts: 338
    edited 2007-06-17 15:00
    The shaking will be a constant "rumble" in my signal. A collision will be a sharp, sudden increase that lasts for maybe 1-2 samples max.
    I plotted the X and Y displacement values and then added the total distance from the origin. What came out was quite interesting. The collisions really stand out now from the background noise from the sensor. I have not tested this with the standard noise you get from running the bot on a normal floor, but this probably something I can use. The formula I used to calculate the distance from origin is SQRT(X^2+X^2). I am sure if I calibrated my X and Y values a bit better than merely subtracting 2500 to get a 0-point value I would get a much better peak.
    As for it not being polite to bump into things, it is better to be prepared for the unlikely event your other sensors do not pick it up than to not be able to handle it at all [noparse]:)[/noparse] Nothing is more impolite than a robot that doesn't know when to stop trying to ride up your leg! This is more of an exercise in how to detect certain events than something that would actually end up in a robot I would use to traverse a maze, for example.
    Gr,
    Mightor
    577 x 303 - 12K
  • edited 2007-06-18 02:31
    Mightor,
    As a first cut, try adding some code that keeps a running average of the measurements. The collision detection code can then compare a potential collision event to, say, an average of the last ten measurements.
    Andy
    P.S. This is a really cool project!
    Andy Lindsay
    Education Department
    edited 2007-06-18 02:58
    Mightor,
    I'll second that!! neat project!! I think you are on the right track by taking the Delta from one sample to the next. This value should be directly proportional to acceleration/deceleration or·in your case as an "impact".
    A·higher Delta value would translate to a more forceful impact. Normal acceleration/deceleration could be filtered out simply by setting a threshold value.
    Beau Schwabe
    IC Layout Engineer
  • edited 2007-06-18 03:51
    Yeah, forget what I said about averaging.· Beau is right; delta should be the first thing to try.· It's simpler and should work as well, if not better, using less resources.
    Andy Lindsay
    Post Edited (Andy Lindsay (Parallax)) : 6/18/2007 4:07:18 AM GMT
    edited 2007-06-18 04:12
    Well guys, this is the code I had last night. I had indeed a rolling average algorithm in it with peak detection (only read your posts this morning, so it's either great mind think alike or fools seldom differ, you pick, hehe). I don't add the detected peaks to the rolling average as this would really screw with the overall average value.
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    total     CON    512
    dataptr   VAR    Word
    avgBy     CON    4
    x         VAR    Word
    y         VAR    Word
    tmpdist   VAR    Word
    dist      VAR    Word(avgBy)
    avgdist   VAR    Word
    avgCount  VAR    Word
    index     VAR    Nib
    FREQOUT 1, 50, 4500
    ' set all values to 0
    FOR index = 0 TO avgBy - 1
      dist(index) = 1
    NEXT
    PAUSE 3000
    FREQOUT 1, 50, 4500
    FREQOUT 1, 50, 2000
    index = 0
    'FOR dataptr = 0 TO total STEP 8
    DO
      PULSIN 6, 1, x
      PULSIN 7, 1, y
      avgdist = 0
      FOR avgCount = 0 TO avgBy - 1
        avgdist = avgdist + dist(avgCount)
      NEXT
      avgdist = avgdist / 4
      tmpdist = SQR ((X * X) + (Y * Y))
      'WRITE dataptr, Word x, Word y, Word avgdist, Word tmpdist
      IF ABS (tmpdist - avgdist) < 70 THEN
        dist(index) = tmpdist
        index = (index + 1) // avgBy
      ELSE
        FREQOUT 1, 50, 3000
        PAUSE 3000
      ENDIF
      PULSOUT 13, 850
      PULSOUT 12, 650
      PAUSE 20
    LOOP
    'NEXT
    FREQOUT 1, 100, 2000
    '  READ dataptr, Word x, Word y, Word avgdist, Word tmpdist
    '  DEBUG SDEC x, ",", SDEC y, ",", DEC avgdist, ",", DEC tmpdist, CR
    'NEXT
    You can tell by the way I have commented out certain parts that this was to allow me to run and do audible inspection of when a collision was detected. I have a living room covered in nice stone tiles so this is *really* throwing off my collision detection [noparse]:)[/noparse] I've been tweaking with the max spike value (70 in this code), but I am sure someone in a room with NO tiles would not suffer from this problem and could use something closer to 30 or so. Please note that this code is not optimised as much as I am sure it can be.
    If you uncomment the bits that do the datalogging and the comment out the motor control lines, you can run the program on your table top and get the values in the debug window in a nice CSV format. To get simulated collisions, just tap the bot on its side, etc. You will notice differently shaped spikes in your graphs, but the total displacement value will always be high. You could use the X and Y values to calculate the angle from which the collision came, the displacement is basically just the hypotenuse. The bot's response could be tailored to these values.
    Things that I still need to implement include a way to temporarily disable the shock detection when the bot is changing direction or starting up as I found that I get beeps whenever that happens.
    I have included the graph and example csv file for your dataplotting pleasure.
    Gr,
    Mightor
    edited 2007-06-18 04:21
    Mightor,
    Thinking about this a little further, if you convert the Cartesian coordinate values to polar coordinates you are left with an angle·and magnitude value.
    Monitor the magnitude above a certain threshold to detect a collision, and look at the angle to determine direction. <--180 degrees out of phase from there should give you the location of·impact.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-18 04:59
    Mightor,
    Here is an interesting "window averaging/tracking" technique that might be of interest.
    ....The only stipulation is that for what ever series of numbers you introduce, the Result
    of multiplying the Number of Samples by the MAXimum InputData value does not exceed 65535.
    Also your data InputData value must be a positive number.
    That means for a InputData value that stays within a NIBBLE, you could have a maximum of
    4096 Samples representing your average. A BYTE would allow for 256 Samples.
    For yor current code, since your highest value for X or Y is limited to +/- 625 ...
    ...You will need to scale it so that it remains positive.· To do this just add 625, so now it ranges from 0 to 1250
    When looking at the average, simply subtract 625 to reconstruct·the signed value.
    With a "high" value of only 1250, you could 'fit' about 52 averaged samples using the method below.
    Maximum # of Samples = 65535 / 'MAXimum InputData value' =· 52.428 = 52
    InputData ... defined as a WORD
    DataBase ... defined as a WORD
    Samples ... defined as a constant
    Average ... defined as a WORD
    MainLoop:
    'Get value for InputData Here
    DataBase = DataBase - Average + InputData
    Average = DataBase / Samples
    goto MainLoop
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/18/2007 5:50:28 AM GMT
    edited 2007-06-18 05:05
    I am not really great at maths, so I will need to do some reading up on polar coordinates, but from your description it's basically a really nice way to describe a vector and the 180 degree phase shift is Newton's 3rd law [noparse]:)[/noparse] Gotta love physics.
    I am not sure I follow your window averaging/tracking algorithm. Could you explain it a bit more? How does this differ from the rolling average algorithm?
    Gr,
    Mightor
    edited 2007-06-18 05:39
    Mightor,
    For distance or magnitude, you already have the formula.... for angle, check out the ATN function built into the BS2... You might need to scale your values down just a bit for the function to properly work, but for what you are doing and determining direction it should be adequate.·· ...If you want also check out the HYP function, that's basically your distance formula.
    Initailly Average starts out as zero and DataBase starts out as zero. As the Input data propagates through the formula iteration after iteration, the result is a "running average Window" of your InputData.
    Think of it this way, look at the formula....
    Normally if you have a DataBase that has accumulated the value of say 10 samples, then in order to find the average you would divide the database by 10 right?
    ...and that's basically what you see in the last line of the formula. Think about what would happen if the InputData value was relatively constant. You would expect the Average value to equal something very close to the InputData value. The First line basically skims off the top of the DataBase by subtracting the Average and replacing it with the InputData value. This way new data can be introduced to the system and you can maintain a "running average Window" of a fixed number of samples.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/18/2007 5:52:52 AM GMT
    edited 2007-06-18 05:53
    Ah yes, I get it now. This is much nicer than using an array and having to keep track of an index. I will be sure to implement this in my code. Thanks for that!
    I was also reading up on polar coordinates and it seems I will need to scale down to -127 to +127 in order to be able to work with the ATN function. That will then also allow me to have a much larger number of samples for the averaging algorithm. Scaling down will also further dampen the low value rumble you get from running the bot. The spikes will still be big enough to stand out from the noise.
    Shame I am in the office now, otherwise I'd be testing this out right now! I'll have to wait another 8 hours, hehe. I guess this is not something that would apply to your jobs. Your boss would probably think it weird if you're NOT messing around with robots in the office.
    Gr,
    Mightor
    edited 2007-06-18 06:05
    Mightor,
    You should only need to scale down for the direction by a factor of 5.
    I personally would leave the resolution that you currently have for·impact measurements.
    "I have a living room covered in nice stone tiles so this is *really* throwing off my collision detection [noparse]:)[/noparse]"
    This now becomes an issue or question... "Can my vehicle survive normal road terrain impact?"
    Set a threshold level that you are comfortable with... Reduce the speed or get bigger tires [noparse]:o[/noparse]) ...Anything under threshold is considered fare game.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-18 06:21
    The scaling idea sounds good. As for bigger tires, I'd love to but then my digital encoders won't work. I am not using them right now but they're attached to the bot and I'd love to use them very soon. I will run some more data logging runs this evening and see what kind of values the tile ridges give me and how they compare to the spikes from a normal collision. I just really hope they're not too close [noparse]:)[/noparse]
    There's a proper model shop (for RC cars, boats, planes, copters, etc) with all the components a robot maker could dream of, in a town about 45 minute's drive from my house. I think I might pop down there to see what they have in lieu of air filled tires. Hopefully they have ones with spokes like the ones that come with the original Boe-Bot so I can continue to use my encoders.
    A month ago I would never have guessed this robot building stuff was this creative.
    Gr,
    Mightor
    edited 2007-06-19 17:28
    Well, I did some more testing. This time I tweaked the program a little to incorporate the alternative averaging algorithm and reinsert the data logging. At first I found that the servos would stutter when put under load. I tracked this down to the WRITE call I was making with 4 Word-sized variables. I cut it down to just 2 Words (average and current displacement) and this seemed to cut down on the stuttering.
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    total     CON    512
    dataptr   VAR    Word
    avgBy     CON    4
    x         VAR    Word
    y         VAR    Word
    tmpdist   VAR    Word
    avgdist   VAR    Word
    avgCount  VAR    Word
    index     VAR    Nib
    database  VAR    Word
    FREQOUT 1, 50, 4500
    database = 4
    PAUSE 3000
    FREQOUT 1, 50, 4500
    FREQOUT 1, 50, 2000
      PULSIN 6, 1, x
      PULSIN 7, 1, y
      avgdist = database / avgBy
      tmpdist = Y HYP X
      WRITE dataptr, Word avgdist, Word tmpdist
        database = database - avgdist + tmpdist
      ENDIF
      PULSOUT 13, 850
      PULSOUT 12, 650
    NEXT
      READ dataptr, Word avgdist, Word tmpdist
      DEBUG DEC avgdist, ",", DEC tmpdist, CR
    NEXT
    Please note that no optimization has been done with regards to the number of vars. I did not have to readjust the offset of the X or Y values as I am using the total displacement in my averaging sum which is always positive (no such thing as a negative sized hypotenuse).
    When I ran the bot on the tiles, I recorded quite massive displacements in the data. The tiles are pretty big, about 20x40cms and the grouting is quite wide. Check the distance-tiledfloor.png for more details (attached). The last spike is the bot colliding with a big immovable object.
    I then placed the bot on a nice smooth surface, a 70x70cms big piece of plywood. The data shows no major displacement except when it finally hits the big object. See distance-smoothfloor.png for more details (attached).
    Please note that in both graphs you see a big spike in the beginning. This is due to the robot accelerating from 0. Ideally you would stop logging whenever the bot is changing direction or accelerating.
    With the tiled floor there is no real way to distinguish between a collision spike and entering or exiting a grout dip. A solution to this would be either to do additional checking on the speed of the robot. This could be done with the digital encoders. However, I noticed that slippage of the wheels would give false readings to the encoders, leading it to believe that is was still moving. The other solution would be air filled tires to dampen the grout induced vibrations.
    I've also noticed that there is almost no time left to do much of anything else besides the logging without causing the servos to stutter. This would of course completely throw off any kind of logging you might want to do. If the logging is left out, you could do some rudimentary directional control. A faster variant of the Basic Stamp 2 would probably be able to overcome this limitation. I am using the standard Basic Stamp 2 which runs at a little under half the speed of a 2SX.
    So there you go. If someone has other ideas as to how I could distinguish between hitting grout and a large immovable object I'd love to hear it!
    Gr,
    Mightor
    626 x 310 - 10K
    629 x 310 - 10K
    edited 2007-06-20 03:06
    Mightor,
    Can you post the data you used in Excel?· ... and maybe the data for a couple more runs on the tile?
    I see a pattern that might lead to a way to distinguish rough terrain from a collision, but more data is required fro this observation to be valid.
    Basically if you set a threshold of say 100 or even 120·by your latest data and look at the "Actual", then there are three points or events of interest.
    If you look at the "Average" value before (point #1) and after (Point #2) each of the three events and calculate the slope between the two points,
    a rough terrain would produce a higher slope than a terrain that was not so rough.· The idea here is to use this slope value in a scaling technique
    towards the "Actual" data.· A higher·slope would bump the Collision threshold slightly higher than a lower slope would allow.
    The attached image might be more intuitive as far as what I am trying to describe.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/20/2007 3:12:13 AM GMT
    1235 x 597 - 103K
    PLOT.JPG 103.4K
    edited 2007-06-20 04:02
    Sorry I couldn't respond to you earlier. I am in CEST timezone so I just got up [noparse]:)[/noparse] (and 5:30am is no time for a sane human being to be getting up at)
    As for the actual datafile, no, I don't have it anymore, so I went ahead and did another run. I have both the CSV file and the Excel sheet, so take your pick. The spikes are shaped slightly differently but I guess that's only normal.
    Note that I don't have the X and Y values for reasons mentioned in my previous post: IC slowness and stuttering servos when logging too much data. The stuttering servos would most likely introduce even more excessive shaking and spikes.
    Thanks for looking at this stuff, btw!
    Gr,
    Mightor
    edited 2007-06-20 05:21
    As spotted by Beau, the data in the Excel sheet and therefore also in the graph is actually based on 3 runs, not just one. Run 1 is from row 1-65 and does not involve a collision, just a bumpy surface. Run 2 which goes from row 66-130 was me getting annoyed with the bot stopping just short of the target it was supposed to hit and picking it up, so ignore that data. Run 3 goes from 131 onwards and involves a final collision with the object.
    Gr,
    Mightor
    edited 2007-06-20 07:38
    Neat project!
    After your comments about the servos stuttering, I'm looking for some way to speed up the loop. Of course the biggest time hog is the PULSIN for the two Memsic axes. Each one of those takes up to 10 milliseconds. You already cut down on the number of readings in the WRITE to the log file. To recover a few of milliseconds more, it looks like the program could get by to log bytes instead of words, as the largest value I see in the data so far is 180. That could get larger with bigger g-forces, though. Also, no need to store dataptr as it is predetermined. The program has aroud 5 milliseconds after the end of the Y pulse, to do all its stuff and get back to catch the next PULSIN. It is a kind of lockstep timing issue. Too bad you can't take readings from X and Y in alternate passes through the loop. But for best accuracy on the HYP operator, they have to be practically simultaneous.
    That got me to thinking. How is the MEMSIC mounted in the Bot, I mean, what orientation?
    The largest reading I see is around 180 for the magnitude. Following the calculation in the data sheet, that amounts to around 288 milli-Gs. Is that right? (180 BS2 time units * 2 microseconds/ BS2 time unit = 360 microsecond deviation from center. 360 / 10 * 8 = 288.) I don't know what to make of it. I'm interested in whatever analysis Beau can come up with.
    Have you tried a larger value of "avgBy", say 6 or 8? That would smooth out the average more. I was kind of worried by the term,
    IF ABS (tmpdist - avgdist) < 70 THEN ... ' only allow averaging on small exursions
    It seems to be working okay, but it might lock up in some more extreme conditions. I don't know. Maybe a failsafe term so as time passes without the condition being satisfied, the window gets larger.
    Tracy Allen
    www.emesystems.com
    edited 2007-06-20 08:05
    The MEMSIC is mounted pretty much the same way as in Figure 3-14 on page 84 in Smart Sensors and Applications v1.0. Of course the bot is not on its side, but it's pretty much the same spot the sensor is mounted on the breadboard [noparse]:)[/noparse]
    I have never had a displacement value go above about 200. I think I'd probably cause damage to the frame if I did try because I had to hit the bot quite hard to get it to go that high. A Byte would probably suffice to hold the data.
    As for taking more readings to calculate the average this is definitely a possibility. I will implement it this afternoon when I get home from the office. As for the value in the "IF ABS (tmpdist - avgdist) < 70 THEN" line, it was the average amount of displacement I found would give the fewest false positives when the bot was NOT moving and I would just tap the bot in various places to simulate a collision. It's been that value for a while now and would probably require readjustment now that I am doing tests on the tiles. However, a difference of 70 between the average and the actual value is quite a lot and a larger value might end up absorbing genuine collisions into the calculations. Experimenting some more will prove or disprove that [noparse]:)[/noparse]
    Gr,
    Mightor
    edited 2007-06-20 17:21
    Hey there,
    I modified the program (see attached). I also attached all the data from the 8 runs that I did:
    2 x Smooth surface, no collisions
    2 x Smooth surface, collision
    2 x Tiled surface, no collisions
    2 x Tiled surface, collision
    Modifications include:
    * logging 2 bytes instead of 2 Words
    * extensive comments
    * average of 8 measurements instead of 4
    Let me know if this is of any help. The first two sheets in the Excel contain the graphs, the others contain the raw data.
    Gr,
    Mightor
    edited 2007-06-21 04:21
    Mightor,
    Yeah, this is tough... Forget the averaging, unless you use that for the general noise floor comparison.· The simple formula that I tried out basically looks at the magnitude value just before
    a spike, and immediately afterwards upon the next sample.· From there it tries to determine a slope·between those two points ranging in value from 0 to 1.·
    Threshold = 100
    SlopeScale = 400
    IF Actual > Threshold THEN
       IF Slope X SlopeScale < Actual THEN
          {Collision Detected}
       ELSE
          {Collision Not Detected}
       END IF
    END IF
    Slope: (Note: Slope value is delayed by one sample)
    IF N1>N2 THEN
       Slope = N2/N1
    ELSE
       Slope = N1/N2
    END IF
    Where N1 is 'Past Actual' (The previous reading of 'Actual')
    Where N2 is 'Future Actual' (The next reading of 'Actual')
    If there is·little difference between the two points, the slope value will be closer to 1 indicating that the vehicle is at least still moving.· A larger difference between the two points, the slope·value will be closer to 0 indicating that the vehicle has stopped (<--all be it momentarily)·or abruptly changed its direction.· The slope value is then used to scale a comparison against the Actual (RAW) data to determine a collision.
    Based on this sort of thinking, it might be more intuitive to step back and take a look at just the raw sensor values without any calculation.· This way you can also derive values such as theta
    implementing 'Delta Theta' transitions in addition to G strength comparisons.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 6/21/2007 5:34:57 AM GMT
    1000 x 645 - 80K
    edited 2007-06-21 05:07
    Hey Beau,
    That looks great, unfortunately I won't be able to try this out until tomorrow; I'm in the office now and this evening I'm having some people over. Damn those timezone differences (and social engagements) I was wondering what you used in Excel to create the collision detected line?
    As for logging both X and Y as well, I don't think this is a problem. The values should fit inside a Byte, I have never seen them go beyond 200 or so and that's with a really violent jolt to the bot. If the hypotenuse fits inside one, the sides definitely should [noparse]:)[/noparse] Seeing as logging 2 Words went without a hitch, I can't see 4 Bytes running into issues. I will have the data for you tomorrow.
    Could you explain to me what you mean by "theta" values? Is this the angle at which the impact occurred? I wouldn't want to assume that impacts always happen from the front, they could come in from the side as well. I suppose seeing as the wheels are in a fixed position, the "shockwave" produced by them getting hit would always come from roughly the same angles; practically 90 degrees on each side of the sensor.
    Who knew crashing things was this much fun?
    Gr,
    Mightor
    edited 2007-06-21 05:25
    "I was wondering what you used in Excel to create the collision detected line?"
    See attached image ... look in the cell edit window
    "Could you explain to me what you mean by "theta" values? Is this the angle at which the impact occurred?"
    Yes
    "I wouldn't want to assume that impacts always happen from the front, they could come in from the side as well. I suppose seeing as the wheels are in a fixed position, the "shockwave" produced by them getting hit would always come from roughly the same angles; practically 90 degrees on each side of the sensor."
    Any impact even side impacts should produce a detectable result.·
    Beau Schwabe
    IC Layout Engineer
    555 x 247 - 58K
    edited 2007-06-21 05:36
    Thanks for the Excel formula, I've never really messed with things like conditionals there.
    I bet a 3D inclinometer detector would be a lot more useful in this case. A collision would produce a vector at an almost horizontal plane, but going in and out of the grout would produce one at a much more vertical angle (down or up, depending on whether the bot is going in or out of the grout). Unfortunately I don't have one so I guess we'll have to make do with the MX2125 [noparse]:)[/noparse]
    Gr,
    Mightor
    edited 2007-06-23 07:14
    Beau,
    Apologies for the delay, real life stuff crept up so I didn't get around to getting the data you needed. However, I have it now. I recorded theta, current and average displacement. I couldn't record the raw values of X and Y because that would've made the servos stutter (I tested it).
    Please note that theta is in BRADS, this is what ATN outputs by default and I didn't want to do any more maths on the stamp than I really needed to.
    From run 3 onwards you can see how theta seems to undulate very regularly. This must be due to the motion of the wheels.
    In run 4 my bot ran off the smooth surface and onto another smooth surface, so the spike towards the end of that run can be ignored as it shouldn't have happened [noparse]:)[/noparse]
    I am not sure how to plot theta somehow onto the rest of the data so you can compare it. I am hoping you have a better idea.
    Gr,
    Mightor
    Edited: added new source code, added (fuzzy) picture to show sensor orientation. Apologies for the terrible quality, I blame my Zire 72.
    Post Edited (Mightor) : 6/23/2007 7:51:02 AM GMT
    edited 2007-06-23 09:15
    I ran some extra tests to see what the average values of X and Y are when the bot is at rest. I wrote a quick little program (see attached) to take 512 measurements and get the average. The first run really threw me off. The X values were fluctuating like crazy and the Y values to a lesser extend. I wasn't quite sure what it was caused by but when I put my hand flat on the desk I could feel the faint vibrations from the PSU fan of the PC in my desk. I had no idea the MX2125 was that sensitive [noparse]:)[/noparse]
    When I ran it again with the bot on the window sill, I found the values to be a LOT more stable. I think with a setup like this you could probably detect a bird passing wind in a tree 100m away.
    I attached the xls file with the raw values and the charts which have been attached as pngs as well (for those who don't have/won't use Excel).
    Gr,
    Mightor
    edited 2007-06-24 03:20
    Mightor,
    No need to apologize... The latest data (robot-runs-theta.zip) is the most compelling as far as trying to discriminate a collision vs. noise.
    "I am not sure how to plot theta somehow onto the rest of the data so you can compare it. I am hoping you have a better idea."
    All you need to do is plot the difference or change in theta. It doesn’t really matter what direction your going or if it's in BRADS, DEG's, or
    whatever, the main thing is to look for change, and how big that change is..... Delta theta = ABS(previous Sample - current Sample)
    The attachment I have included has four series of data for each of the 6 runs .... Average (Series 1) ; Current (Series 2) ; Delta theta (Series4) .... Ignore Series 3 (Empty Column)
    Something to note: Each time a collision occurs, 'Delta theta' gets dramatically knocked down for at least 3 to 4 samples during/after the event.
    It's a definite window to look for based on the current data that has been made available.
    BTW) I think that your columns for Average and Current in the last data set you provided are swapped with each other.
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-24 15:00
    Beau,
    I think I may have an explanation for the delta theta being knocked down for a while after a collision. I think it is due to the bot's servos still running but the bot not moving. That would cause a pretty consistent displacement from a very particular angle.
    Btw, think the way I've been handling the delta theta is a bit wrong. Say I have a theta of 250 brads and 5 brads. Now normally you would get a delta of 245 brads. However, if you look at it from the other direction, you'd only get a delta of 10 brads. In theory we should never have a delta of more than 128 brads.
    I will work on implementing this on the bot and will post the data file soonest.
    Gr,
    Mightor
    edited 2007-06-24 17:21
    Mightor,
    You said...
    Your absolutely right! .... Delta Theta should be something like this ....
    IF Delta theta > 128 then
        Delta theta = 255 - Delta theta
    END IF
    ...I re-ran the data, but I feel as though the data is only allowing us to see half a dozen of one thing and six of another. At this point in order to derive anything from the data... Delta, average, whatever, nothing but the raw X and Y values should be logged. Throwing other stuff in there at the moment does not necessarily help things. I have modified your Collision detection program
    so that it will acquire 192 samples for X and Y (See attached)
    Beau Schwabe
    IC Layout Engineer
    edited 2007-06-24 21:00
    Hey Beau,
    I downloaded your code and modified it so it would log X and Y as Word-sized vars to make sure it got logged completely.
    I slapped all the data into an Excel sheet but I am getting quite a few /0 errors, hehe. I am by no means an Excel wizard and as it's close to 11pm here, my brain is slowly starting to melt.
    I've attached the Excel sheet with the raw X and Y data, as well as theta (I hope I got the right formula for this one) and the displacement. I'll have a better look tomorrow morning and see if I can't extract some more info out of this.
    Btw, I really appreciate you putting so much time and effort into helping me figure this out!
    Gr,
    Mightor
