DS1620 and Measuring Temp with Tenths Accuracy
I modified the existing code for the DS1620 two measure two DS1620 temp sensors.
I was wondering if anyone can suggest some code modifications to measure with tenths
accuracy, such as 23.5 deg. Currently only displays the whole number. DS1620 data sheet
says it can measure in increments of 0.5 deg.
' {$STAMP BS2}
' {$PBASIC 2.5}
' Program: DS1620.BS2 (interface DS1620 digital thermometer to BS2)
' This program interfaces the DS1620 Digital Thermometer to
' the BS2. Input and output routines can be combined to set
' the '1620 for thermometer or thermostat operation, read
' or write nonvolatile temperature setpoints and configuration
' data. In addition to using the BS2's new Shiftin and Shiftout
' instructions to communicate with the 1620, this program uses
' new math and display operators that work with signed integers.
' This makes it relatively easy to convert between degrees C and
' F and to display both positive and negative temperature
' readings. Note that after math operations on negative numbers
' it's necessary to "extend the sign bits." All this means is
' setting all of the bits to the left of actual value to 1s.
' Also note the use of the new */ (pronounced 'star-slash')
' operator. This works like multiplying by an integer (0-255)
' and a fraction (in units of 1/256). For example, to multiply
' 17 by Pi (approx 3.1416) would be written "17 */ $0324."
' The second value is written in hex to emphasize that it's being
' split into bytes: $03 is the integer and $24/$100 is the fraction.
' In the C-to-F conversion below, we multiply the C value by 1.8
' with "*/ $01CC" since $CC/$FF (204/256) = 0.8.
' ===================== Define Pins and Variables ================
' Define for DS1620 Temp Sensor 1 and Temp Sensor 2
DQ1 CON 2··································· ' PIN 2 <=> DQ.
DQ2 CON 4··································· ' PIN 4 <=> DQ.
CLK CON 1··································· ' Pin 1 => CLK.
RST1 CON 0·································· ' Pin 0 => RST (high = active).
RST2 CON 3·································· ' Pin 3 => RST (high = active).
DSdata1 VAR Word···························· ' Word variable to hold 9-bit data.
DSdata2 VAR Word···························· ' Word variable to hold 9-bit data.
Sign1 VAR DSdata1.BIT8······················ ' Sign bit of raw temperature data.
Sign2 VAR DSdata2.BIT8······················ ' Sign bit of raw temperature data.
T_sign1 VAR Bit····························· ' Saved sign bit for converted temperature.
T_sign2 VAR Bit····························· ' Saved sign bit for converted temperature.
' ===================== Define DS1620 Constants ===================
' >>> Constants for configuring the DS1620
Rconfig CON $AC···························· ' Protocol for 'Read Configuration.'
Wconfig CON $0C···························· ' Protocol for 'Write Configuration.'
CPU CON %10································ ' Config bit: serial thermometer mode.
ONeshot CON %01···························· ' Config bit: one conversion per start request.
Cont CON %00······························· ' Config bit: continuous conversions after start.
' >>> Constants for serial thermometer applications.
StartC CON $EE····························· ' Protocol for 'Start Conversion.'
StopC CON $22······························ ' Protocol for 'Stop Conversion.'
Rtemp CON $AA······························ ' Protocol for 'Read Temperature.'
MoveTo········· CON···· 2······················ ' for DEBUG control
ClrRt·········· CON···· 11····················· ' clear DEBUG line to right
' ===================== Begin Program ============================
LOW RST1···································· ' Deactivate '1620#1 for now.
HIGH CLK
PAUSE 100
HIGH RST1
SHIFTOUT DQ1,CLK,LSBFIRST,[noparse][[/noparse]Wconfig,CPU+Cont] ' ..temp conversions.
LOW RST1···································· ' Deactivate '1620#2 for now.
PAUSE 50
HIGH RST1
SHIFTOUT DQ1,CLK,LSBFIRST,[noparse][[/noparse]StartC]·········· ' Send #1 start-conversion protocol.
LOW RST1
LOW RST2
HIGH CLK
PAUSE 100
HIGH RST2
SHIFTOUT DQ2,CLK,LSBFIRST,[noparse][[/noparse]Wconfig,CPU+Cont] ' ..temp conversions.
LOW RST2
PAUSE 50
HIGH RST2
SHIFTOUT DQ2,CLK,LSBFIRST,[noparse][[/noparse]StartC]·········· ' Send #2 start-conversion protocol.
LOW RST2
' The loop below continuously reads the latest temperature from
' the DS1620.
again:
PAUSE 500···································· ' Wait 0.5 second between readings.
HIGH RST1···································· ' Activate the '1620 #1.
SHIFTOUT DQ1,CLK,LSBFIRST,[noparse][[/noparse]Rtemp]············ ' Request to read #1 temperature.
SHIFTIN DQ1,CLK,LSBPRE,[noparse][[/noparse]DSdata1\9]··········· ' Get the temperature reading.
LOW RST1
T_sign1 = Sign1······························ ' Save the sign bit of the reading #1.
DSdata1 = DSdata1/2·························· ' Scale reading to whole degrees C of#1.
HIGH RST2···································· ' Activate the '1620 #2.
SHIFTOUT DQ2,CLK,LSBFIRST,[noparse][[/noparse]Rtemp]············ ' Request to read #2 temperature.
SHIFTIN DQ2,CLK,LSBPRE,[noparse][[/noparse]DSdata2\9]··········· ' Get the temperature reading.
LOW RST2
T_sign2 = Sign2······························ ' Save the sign bit of the reading #2.
DSdata2 = DSdata2/2·························· ' Scale reading to whole degrees C of#2.
DEBUG CLS
'DEBUG MoveTo, 0, 3
DEBUG "Temp Sensor #1", CR
DEBUG "
", CR
DEBUG SDEC DSdata1," Sensor 1 degrees C",CR·· ' Show signed temperature in C.
DSdata1 = (DSdata1 */ $01CC)················· ' Multiply by 1.8.
DSdata1 = DSdata1 + 32······················· ' Complete the conversion.
DEBUG SDEC DSdata1," Sensor 1 degrees F",CR·· ' Show signed temperature in F.
DEBUG "············· ", CR
DEBUG "Temp Sensor #2", CR
DEBUG "
", CR
DEBUG SDEC DSdata2," Sensor 2 degrees C",CR·· ' Show signed temperature in C.
DSdata2 = (DSdata2 */ $01CC)················· ' Multiply by 1.8.
DSdata2 = DSdata2 + 32······················· ' Complete the conversion.
DEBUG SDEC DSdata2," Sensor 2 degrees F",CR·· ' Show signed temperature in F.
GOTO again··································· ' Repeat forever.
' {$STAMP BS2}
' {$PBASIC 2.5}
HIGH CLK
PAUSE 100
HIGH RST1
PAUSE 50
HIGH RST1
LOW RST1
LOW RST2
HIGH CLK
PAUSE 100
HIGH RST2
LOW RST2
PAUSE 50
HIGH RST2
LOW RST2
' the DS1620.
again:
LOW RST1
LOW RST2
DEBUG CLS
'DEBUG MoveTo, 0, 3
DEBUG "
", CR
DEBUG "
", CR
Tracy Allen
www.emesystems.com
