Encoder for Boebot using CNY70
Hello,
I want to make encoders for my Boebot and since the wheels are directly srewed on the servo's axes,
there is no room to mount an encoder wheel onto the axes.
The alternative I have in mind is to use the CNY70 which is a "Reflective Optical Sensor" and can be
mounted at one side of the wheel. The sensor should detect the black and white sections on the
encoder "print" put at the inside of the wheel. I hope one get the picture :<))
Does anyone have experience with the CNY70 because I wonder how "reflective" the print
must be. Can I just use regular paper with black and white sectors as Mr. Whit showed to us
in his mail today?
Thank you,
Ed
in his mail today?
Thank you,
Ed
I guess you have seen the Parallax digital encoder - http://www.parallax.com/detail.asp?product_id=28107
You also might take a look at this. http://www.nubotics.com/products/ww01/index.html
You could print the encoder wheels on a reflective sticker as nubotics does - I'm not sure how what the CNY70 would need.
Good luck.
Whit+
yes I'm aware of the Parallax encoder. As usual a lot of documentation and an advanced design compared to what I have in mind.
The Parallax set use the IR modulated signal and as a result is less or not sensitive to ambient light. My set-up is not that sophisticated.
But, it is difficult and costly to get Parallax stuff. There is one distributor in the Benelux and the minimum order is 250 Euro unless
one pays an extra 17 Euro for handling cost. The encoder cost 35 so .. I wait till Christmas and make a big order :<)))
In the meantime I will do some experiments.
Thanks for the reply and the black & white wheel layouts.
Ed
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
--DFaust
--DFaust
--DFaust
- Stephen
Thanks for all of the input.
