Comunicate BS2 to BS2
Hello I want to comunicate several basic stamps to a master one. Do you know if that subject has been discussed in another forum or can someone give me advice? Thank you
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
Specifically N&V volumes 55 & 56.
Also, Stamp to Stamp communication can be found in "Basic Stamp 2p Commands, Features and Projects".
Hope this helps.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
Again, thank you all.
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
There's no reason why you can't use different model Stamps on the same "network". Just be careful with the Baud rate values since they vary between Stamp models ... the manual has them all in the SERIN / SEROUT chapters.
The Internet Netburner and the EmbeddedBlue Transceiver can both be used to establish networks, but they're more expensive than a length of cable. Consider using xBee instead (www.selmaware.com) since it uses less power and is smaller. There are AppMod adapters available and coding examples. You can also get PC USB adapters so you can add your PC to the network.
