Accelerometer Questions
I am new to the propeller, and hopefully I recieve it today in the mail! My project is a datalogger for my car (logging MAP, throttle position, RPM, etc), and wanted to have acceleration data from it to.· I was able to get some free samples of the ST accelerometer, E-LIS3L02AS4.·I read up on them and was thinking to try and cancel out some of the noise and error, I'd use two accelerometers.· I don't know if this would help or not.· If it does, would it be better to mount them perpendicular to each other or parallel?
Also, does anyone know if that sensor I sampled would be semi-accurate for inertial navigation (i.e. double integrate acceleration data to get position data)?· I know the longer you try and do that the more drift you get.· I want to be able to record an autocross run (under a minute), and within a couple of feet would be amazing.·
My goal is to be able to have a visual of my path through the course, color coded based on the magnitude of the acceleration vector.· Then put the datalogger in my buddy's car, and see what lines he's taking and how he is doing so much better!
Thanks for your time,
Ryan
Ryan
A great idea and use for the Propeller chip. I don't think you are going to get a definitive answer about the inertial navigation question. Just do it, and see how it works. It will be fun and not very expensive to try.
Richard
As far as I know, the only accelerometers capable of that kind of precision are $100,000 military-grade ones used for missile guidance.
Even if I'm wrong, this assumes that the accelerometer is always pointing in the same direction. If the car turns, your data becomes meaningless in a real-world position sense.
As far as finding the postion, since this is about a $50 project, I'm expecting about $50 accuracy, haha. Unfortunatley, a student doesn't have $100,000 to blow on a sensor.· I was thinking since I am using a two-axis accelerometer, then I can make them into a vector (basically pygathorean theorem), therefore finding both new Y and X cordinates based off last position.
Thanks again
Ryan
I agree with Berg. You won't get the precision that you want. But, i recognize that you're doing SCCA. I also recognize that you're looking for bragging rights...
The double integration thing wont' be precise, but if you add a RTC with .01sec accuracy, and use it to trigger your accelerometer readings, you would effectively get the same thing. Plus, you'll have legit data you'll be able to use to make yourself faster.
Keep us posted, maybe I'll steal your code [noparse];)[/noparse]
-Parsko
BTW - I appreciate the $50project => $50 accuracy comment!!!!!!! That is one profound hobbiest statement!!
I started hacking apart the Graphics Demo, and designing my "dashboard".· I want to have one cog display data, one collect sensor variables, one write data to SD, and one to do any math I need to do. I have my display as far as I can go right now, and want to be able to pass values to the "display cog" and have it update with the new values.· I tried creating a new process on a seperate cog and have it just increment values, but I cannot get them to pass through to the other cog.· How would I go about doing this?·
Also, does anyone have a cheat sheet for text colors?· I only can get black, white and blue.
I have attatched my current project.· Please be gentle,
Thanks a lot!
Ryan
As long as you are at it, you might consider an electronic compass. This could be used to stabilize or orient the vehicle in 2-D space, and then the accelerometer could work off of that known orientation.
Also, you wrote of comparing results from two different drivers: I'm working on a project where the Propeller connects to the outside world via Wi-Fi. (Lantronix) Once you get your data logger working, you could make two data loggers, one for each driver. Then, get them communicating with each other, such that you'd be able to see the other driver's data real-time, as you watch your own! (is the course safe enough to be distracted with all this)
Jim C
I'll have to check out the compasses. I'm writing down all of the posibilities to do this, so I can test and see which is the most accurate. I recieve my accelerometers today, so I can start trying. I still don't know how to pass variables around from cog to cog.
Thanks again,
Ryan
Passing variables between cogs is something I want to do too. I think the answer is in EXAMPLE 17 of http://forums.parallax.com/showthread.php?p=574524 (Thanks to Dave Scanlan for the excellent examples).
HTH.
Cheers,
Simon
www.norfolkhelicopterclub.co.uk
You'll always have as many take-offs as landings, the trick is to be sure you can take-off again ;-)
BTW: I type as I'm thinking, so please don't take any offense at my writing style
marty
Lawson - I was looking at some compass IC's earlier today.· I think I will have at least one other IMU device in conjunction with the accelerometers. BTW, they arrived today, so I am going to have to practice my SOIC soldering skills..
Now that I am thinking about it, I can tap into the rear ABS sensors (thats right, REAR... haha FWD) to keep the distances in check.· Not the most accurate, but would be a good sanity check.
Thanks for everyone's help!
Ryan
Post Edited (ry.david) : 6/20/2007 2:54:58 AM GMT
Side note/Project update:· Video output, VGA, Mouse, Keyboard, and SD card are all attatched/soldered and coded in.· Next goes on the accelerometers, and I think I am going to have to order a gyro. Now I just need data...
Thanks in advance!
Ryan
Did you ever get the ST E-LIS3L02AS4 accelerometers working ?
Raf
If you're not crashing, then you're not trying hard enough.
The formula
s = a/2 * t^2
gives you the worst case global error
a_error = n*a + m, with - maybe - n = 1% and m = 0.01 m/s^2
For a = 2m/s^2 and t = 100 s
s_mean = 10 km
s_max =1.01 m/s^2* 10,000 + 0.01* 10.000= 10,1km + 0,1 km
= 200 m @ 10 km
We are the China supplier for the below products:
- Accelerometer (Quartz)
- Dynamical Tuned Gyro
- MEMS Gyro
For Application of our inertial sensor (Accelerometer, Dynamical Tuned Gyroscope), We supply to our clients in China Aerospace, Industry, civil application, and have mainly supplied foreign customers for oil & gas directional drilling fields (Components for borehole surveying instrument, MWD Tools, civil aviatio, etc.)Should you have any interest or need, please do not hesitate to contact me.
Thanks & Best regards,
Jessica Zhang
Ericco International Limited
Address: Room 1603, Sigma mansion, GaoXin Road,XiAn,China
Phone: 029-87545860 Ext.603
Fax:029-87545860/87545861/87545863-601
E-mail: ericco186@163.com
MSN:ericco186@163.com
