2 Problems One with Debug comand and other with reading a sensor
Results:
A/D Reading: 1626
volt Reading: 1.98
pH Value is: 7.07
power filter is off
and
A/D Reading: 1673
volt Reading: 2.04
pH Value is: 8.08
Power filter is onf·· <- Problem # 1 : When the pH goes above·8.00 the message suppose to change to "Power filter on" but I don't know why·
················································· the·" f " is still there. Anyone know how I can·get rid of it?
Problem # 2: Does anyone know how I can get the program to change the Value of the " pH " more frequently like how the A/D Reading and volt reading do? What I mean is as my A/D reading changes so does the voltage reading at the same time but with the pH value it's not changing·as fast as the other values do. For example in my above results the A/D reading and voltage reading change only by a little but the pH value jumps from 7.07 to 8.08 instead of gradually increasing. What do you think that problem could be.
Program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
CS····· CON·· 9······· ' Chip Select
DIO_10· CON·· 10······ ' Data I/O pin 10
CLK···· CON·· 11······ ' Clock
' LTC1298 configuration
AD····· VAR·· Word···· ' Variable to hold 12-bit AD result.
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
pH····· VAR·· Byte···· ' pH value of the water
HIGH CS··············· ' Deactivate ADC to begin.
HIGH DIO_10··········· ' Set data pin for first start bit.
again:
· GOSUB convert···················· ' Get data from ADC.
· GOSUB calc_volt
· DEBUG HOME, "A/D Reading: ",DEC AD,CLREOL,CR
· DEBUG "volt Reading: ",DEC v/100,".",DEC2 v,CLREOL,CR
· DEBUG· "pH Value is: ",DEC pH, ".",DEC2 pH, CR
· PAUSE 500······························· ' Wait a half second.
· GOSUB Filter
·GOTO again······························· ' Endless loop.
Filter:
IF pH > 7 THEN filter_on
IF pH < 8 THEN filter_off
IF pH < 7 THEN filter_on
DEBUG "ph level is greater than 7", CR
RETURN
filter_off:
HIGH 0
LOW 1
DEBUG "power filter is off", CR
PAUSE 500
GOTO again
filter_on:
LOW 0
HIGH 1
DEBUG "Power filter is on", CR
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
config = config | %1011
· LOW CS·································· ' Activate the ADC.
· SHIFTOUT DIO_10,CLK,LSBFIRST,[noparse][[/noparse]config\4]· ' Send config bits.
· SHIFTIN DIO_10,CLK,MSBPOST,[noparse][[/noparse]AD\12]······ ' Get data bits.
· HIGH CS································· ' Deactivate the ADC.
RETURN···································· ' Return to program.
Post Edited (pimp200277) : 6/15/2007 8:08:59 AM GMT
A/D Reading: 1626
volt Reading: 1.98
pH Value is: 7.07
power filter is off
and
A/D Reading: 1673
volt Reading: 2.04
pH Value is: 8.08
Program:
' {$STAMP BS2}
' {$PBASIC 2.5}
' Pin Assignments
config· VAR·· Nib
v······ VAR·· Byte
v2····· VAR·· Byte
again:
· GOSUB calc_volt
· GOSUB Filter
Filter:
RETURN
filter_off:
HIGH 0
LOW 1
PAUSE 500
GOTO again
filter_on:
LOW 0
HIGH 1
RETURN
Calc_Volt:
v = 8000 ** AD
v2 = v * 100
pH = v/025
RETURN
convert:
Power filter is on
notice the first statement has 1 extra letter, the "f"
simply add a space to erase that or clear the screen.
"Power filter is on "
It is because the screen is not cleared before writing. I don't use debug much but there may be a clear screen, or clear rest of line command, or you can clear a line using debug " " any number of spaces. If your numbers vary in length you for sure want to make sure you erase the previous numbers for example.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Post Edited (metron9) : 6/15/2007 12:42:14 PM GMT
The above logic turns the pump on if PH>7 and OFF if PH<7 and the third IF PH <7 never gets executed because the second if PH < 8 is true when PH < 7
IF pH < 7 THEN filter_off
The code above turns the filter on if PH>7 and back off only when PH<7 It has a built in do nothing or Hysteriesis if the PH=7 so for example, if your number has a resolution of .1 then filter on when PH=7.1 or higher and filter goes off if PH=6.9 or lower, you control the hysteriesis with the resolution of your numbers.
You are dropping off the lowest bits in your calculation using the ** operator. To increase the resolution you need to keep the lowest bits in the calculation as well.
The calculations are the same in the code below but you can use this loop to work on your code independently from the ADC readings. It will then be easier to modify your code to get what you want. Substitute your minimum and maximum ADC readings you expect to get in the for next loop, I just picked some numbers. I will need more coffee this morning before actually looking at math problems...
