Pan & Tilt servo controlls?
I've picked up a pan and tilt addon for the Boe-Bot, however the servos it uses are not 360 degree but limited in the amount they can rotate. Does anyone know off hand the pulse commands they are expecting? Odds are I can trial and error it, but if someone has the information I'd rather not repete the work.
Most standard servos work over a PWM range of 1.0ms to 2.0ms with 1.5ms being the center of travel, however your results may vary depending on the servo.
Most servos travel from 140 to 180 degrees over their PWM range.
With a pan and tilt servo system, it is best to actually find the PWM values for the end stops and the center. It only takes a few minutes.
Hope this helps.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
This is actually a good thing -- that 20 to 50 mSec gives your program time to do something else -- like drive a second servo. That way, it has a larger purpose in life than simply running a PWM signal to a single servo.
You missunderstand. I'm sure the servos are NOT 360. Unlike the wheel servos that come with the Boe-Bot kit.
Very good, I'll take a look as soon as I'm no longer supposed to be working.
