Propeller and a Browser — Parallax Forums
comsolcomsol Posts: 7
edited 2007-06-15 13:51 in Propeller 1
Hello all folks,
I search a browser for the propeller chip?
Have everybody a idea I can get this stuff?
best regards: Uwe Reinersmann
  • NewzedNewzed Posts: 2,503
    edited 2007-06-14 22:59
    At Parallax.
    Yesterday is history, tomorrow is a mystery, and today is a gift.
    That is why they call it the present.
    Don't have VGA?
    Newzed@aol.com
    edited 2007-06-14 23:11
    You can purchase the Propeller and accessories here: http://www.parallax.com/propeller/index.asp
    Paul Baker
  • comsolcomsol Posts: 7
    edited 2007-06-14 23:30
    Hello Paul,
    I think it is a mistake.
    I mean a Software, a HTML Browser like IE or Opera. I want connect the
    Propeller Chip via a Serial to TCP Converter to the Internet.
    Best Regards: Uwe Reinersmann
  • JamesxJamesx Posts: 132
    edited 2007-06-15 00:47
    I am trying to do something similar, but use the Propeller to serve up some http and html code. Has anyone written some simple http code, in Spin?
    As for an actual browser that runs on the Propeller, to my knowledge, that's not currently available. That would be something though, if you find one!!
    Jim C
    edited 2007-06-15 03:18
    There is no html browser for the Propeller, it's a little RAM limited to be able to display high color bitmap graphics of large screen resolutions, thats not even going into the whole Ethernet thing.
    Paul Baker
  • computer guycomputer guy Posts: 1,113
    edited 2007-06-15 03:43
    Paul do you think it would be possible for someone to get a propeller with an ethernet port to view plain text web pages.
    Just thought it would be a good place to start with this.
    Many things could be done with this.
    Check out my robot using the propeller robot.tmcp.com.au
    If you offer cheap PCB fabrication, perl programming or any other helpful services please email me at.
    anthonybmyatt@yahoo.com.au
    edited 2007-06-15 03:51
    Yeah a lynx style browser with some ethernet MAC/PHY chip should be possible.
    You could probably also design a site ripper or spider where the contents are pushed to SD card.
    Paul Baker
  • Harrison.Harrison. Posts: 484
    edited 2007-06-15 03:54
    The easiest way is to let a real server do intermediate processing of web pages (kind of like a proxy). In other words, setup a webserver with a php script and let it do all the html processing and text formatting to fit on whatever resolution you are using. Then send the text down to the propeller and let it display it. If you use an xport or siteplayer telnet for the ethernet to serial layer then it would only take maybe 50 lines of spin code + 100 lines of php code on the server.
  • ForrestForrest Posts: 1,341
    edited 2007-06-15 04:02
    Here's a web browser requiring less than 10 KB! www.sics.se/contiki/perspective/the-history-of-contiki.html
    edited 2007-06-15 04:40
    Very cool Forrest. I've never heard of this before.
  • Chris MerckChris Merck Posts: 55
    When we get a C compiler I would not be surprised to see a ConTiki Propeller port.
    "Contiki was designed to be inherently portable as I had developed it in C under FreeBSD and only very late in the process had I written the glue code for making it run on the 6510 CPU of the Commodore 64 using the cc65 C compiler." says the author of ConTiki
