PROpeller Digital Fuel Injection
RinksCustoms
Hello all! After taking the past few months wandering around the forums, and general tinkering with the prop I've come to the conclusion that the prop would make an excellent platform for a DFI that you can tune on the fly without a laptop! A bit of a daunting task for a greenhorn like me. Was hoping Mike Green's OSp (prop OS) would be right up my alley for this project, but i was informed that it still had a few bugs to work out, so i will undoubtedly be here asking questions regarding how to get·an on screen menu system working prop-erly, lol.
I have interested the tallents of benettdan though. He has been working on a FI setup for a whille now using the SX MCU, and is near completion with his project. I'm glad for all his assistance as we bolth have the same truck.
Here's the preliminary outline/feature set:
*Propeller based PMU (Powertrain Management Unit)
*Self contained tuning prog/GUI/menu system
*On-the-fly adjustability (won't be a need to reboot)
*Video (NSTC) output for car·A/V compatibility
*Keyboard/mouse (maybe trackball)·inputs
*Will give stats of powertrain until tunning menu is called
· (will also flash warnings when any stat exceeds a preset limit)
*Ping))) wil be integrated with a cmos camera for reversing
*Three keyfob RFID tags will enable starting of the 500HP twin-turbo engine,
· each tag will enable a different performance level: (valet, half, & full power)
Sensors:
MAF, MAT, MAP (boost/vac), TPS, Knock, Temps (water, oil, EGT, trans), Crank trigger, fuel pressure, Volts,·and Wide-band O2
Actuators:
Solenoid/Servo hybrid (experimental) Wastegate/Blow-off valves, Idle Air Control servo, Trans control module for 4L60E, 6 injector outputs for sequential injection, hybrid boost referenced + servo adjusted fuel pressure regulator.
Phase 1:
· Get the prop to read/write the sensors/actuators properly and write a "basic" program to run the truck at a modest power setting with video output to closely monitor stats.
Phase 2:
· Code a GUI app that will allow kb/mouse inputs to "fine tune" the DFI on-the-fly, set alarm presets, and manage data acquisition/storage/playback (a future enhancement)
Phase 3:
· Integrate add-ons like Ping))), cmos camera, TOUCH screen, and RFID reader
Definetly a E3 (Electronics Engineer Extrodinare!)
"I laugh in the face of imposible,... not because i know it all, ... but because I don't know well enough!"
Post Edited (RinksCustoms) : 6/17/2007 4:42:37 AM GMT
Sensors:
Actuators:
Phase 1:
Phase 2:
Phase 3:
Realize that I am really a mad scientist··· and
Don't forget it!
http://raydillon.com/Images/Illustration/GameArt/WildIsle/WildIsle-Ink-ScientistClose.jpg
see third post
I had a 48 element menu system coded for the BS2 spitting serial to an SX Video module. It was a text based GUI and the menu's were divided into four "buttons" on the screen and had a title bar! The setup would have controlled an array of SPI based electronic pots and A/D converters for a Light Computer/Electronic crossover. Which may be the next project with the prop. It failed because I couldn't get the damn "button" and "case" commands to work right.
Right now i'm tooling with a basic GUI like boeboy's while i'm looking for a shop manual for my truck online. I'll post code if i can get something usable for the rest of you.
Bill
Post Edited (Capt. Quirk) : 6/18/2007 7:27:30 PM GMT
