PIR Sensor is not working properly.
Hi
I have two PIR sensors and they are detecting me
very nice. But after some time they start detecting
even when I am not near them. ( Even when I am
in other room)
I used them in a completely close box
and they continue sensing about 10 times
during an hour.
I thought that a servo motor could be making
some electric noise and I turn off the servo
and all lights but I still have the problem.
Do you know why ?
Thanks, Joe
in other room)
during an hour.
Do you know why ?
Thanks, Joe
A noisy power supply could also contribute. How long are the wires from the power supply or going to the BASIC Stamp from the PIR?
How can I see a "noisy power supply" ?
Do you know where can I find information ?
About the wires , they are abot 2 feet ( 60 cm) long.
Thanks, Joe
Often, the only way to "see" the noise is with a high speed scope. It's much easier to just add some filtering
to see if the problem goes away. I would suggest a 0.1uF ceramic capacitor across the power leads at the PIR.
You could add a 10uF 6V electrolytic capacitor as well or wait to see what happens with the 0.1uF capacitor.
The PIR are working a little better now , thanks.
I forgot to tell that I have a 900 Mhz transmitter
near ( one feet) the PIR and each time
I connet the transmitter , the PIR sensors are being
difficult to read.
Do you know if can I add more capacitors or make and other
change in order to improve the PIR signal ?
Thanks, Joe
PS: the 900 Mhz transmitter output
is about 10 mW ( mili Watts ) only . The transmitter
sends video from a little camera and consumption is
about 150mA at 12 Volts
