Quick question for Tracy Allen..reference "EMIC"
I have done alot of "stamping" using the "emic" device over the years and have had great success with "her...female voice".
There is one little annoying thing however, and that is the 'hiss' one hears in the background while she is speaking.·· I am sure that this hiss is comming from the EMIC as there is probably alot of switching going on inside the device. I was wondering if you, or prehaps someone else has designed and build some sort of audio filter on the output that might filter out this hiss.
Thank you
deno
Thank you
deno
Sid
Yesterday is history, tomorrow is a mystery, and today is a gift.
That is why they call it the present.
Don't have VGA?
Newzed@aol.com
I have used the V-Stamp from RC Systems·(www.rcsys.com) and like that product line·very much.· It's all text-to-speech, so both the hardware and software sides are easy to work with.· The voices are very flexible and·easy to customize.· Off the 'Downloads' tab, choose 'Voice Samples' to take a listen and see what you think.
Tim
I know what you mean about the hiss. The Winbond chip (heart of the EMIC) does not do too well on the sibilants; it is hard to distinguish e.g., "sixteen" from "sixty", because the "n" gets lost in the hiss. It is an annoyance in a voice reporting weather station we have (1-415-381-9463). I haven't come up with a good solution to it. I'll curious to hear what Sid did to improve it. I know the speed and pitch and volume settings do make a big difference, and sometimes you can improve individual words with a phonetic spelling.
That chipset from RC Systems looks pretty interesting, but I hear quite a bit of hiss there too. I guess it is a byproduct of the synthesis.
Maybe an audio compressor could help, a PGA to squelch the gain when the audio is below threshold.
Tracy Allen
www.emesystems.com
Tim
serout tx, T2400, [noparse][[/noparse]say, "Certain, sounds, have, a, hiss,", EOM]
and it came out quite normal.· My setting are vol = 5, spd = 2,
pitch = 0.· Words like fourteen and sixteen are quite clear.
Sid
Don't have VGA?
Newzed@aol.com
Sid
Don't have VGA?
Newzed@aol.com
Will keep at it...thanks...deno
Sid
Don't have VGA?
Newzed@aol.com
As Sid suggested, if it will accept phonemes, another one to try is "UUV".
Bruce Bates
Another example, to say "thank you", I found it much more pleasing to enter it as "thankyou".
Sid, I have no problem understanding it, myself, when played through a good speaker. (but I wonder, how can you tolerate it every 5 minutes!!?) In the application behind the phone number for a hang gliding association, it is going through a DAA and the phone lines, and that adds to the confusion, and the robotic voice and the weak "n"'s are off putting to the occasional listener. When I hear the message that the windspeed was 13 miles per hour, I have to catch myself thinking, "did she say '30', or '13'?", Chris Savage was kind enough to hook us up with an ISD set that we intend to try out, to string together messages spoken in the natural voice of one of the association members, but that is still on a back burner.
Tracy Allen
www.emesystems.com
Sid
Don't have VGA?
Newzed@aol.com
