Printed RFID cards
I would like to print names and possibly a picture on the RFID cards that I purchased from Parallax to make ID cards.· Is there some way to do this at home. ·If there is no real way of doing this, what are the characteristics that I should look at to get them from a source that pre labels the cards??
The easiest way is to glue two cards together (picture id card + rfid tag card). I currently have an ID that has a thicker HID RFID tag that is glued in between two normal printed ID cards.
And maybe give it a thin coat of primer.
Don't visit my new website...
Phil-· It's interesting that you brought up the laminator!!· We tried to do that yesterday.· I will say that the card does work after sending it through.· You have to send the card through about 6 times to get it to seal well, due to the thickness of the card.· I am also in need of a new laminator after the 8th card....·
Gadgetman- I will try your idea today and let you know how it turns out!· I wonder if I sand the card, transfer on a image with transfer paper and then coat it with lacquer or clear paint??
On a similar note in answer to Phil's question... (If you back-light the RFID card with an extremely bright light, you can see the image below) ... It appears that there is only
a very small 1mm square area of concern, this is the actual RFID chip within the card. Most chips are designed to run in the upper temperature range of 100-125 Deg C. They
can usually survive temperatures higher than that, but will not operate at the higher temperature extremes.
Beau Schwabe
IC Layout Engineer
Both thermal transfer and dye sublimation involve heat, but not nearly as much as a laminator produces. Also, you will want to make sure that the plastic used in the RFID card is compatible with whichever process you use.
-Kit
