Prop chip dies!
RichardF
I am the guy having PLL problems driving servos. I thought they had gone away when I rewired everything to eliminate the possibility of RFI causing the PLL to be erradic (is that a word?). It all seemed to work fine after that; then...· Last night while downloading from Prop Tool to EEPROM everything locked up, including my computer. After rebooting the computer, no mor PLL. I can use RCFAST, but nothinig with a crystal. I ordered a new chip so hopefully it will work and my PLL problems will disappear. I intend to send the bad chip back to Parallax for testing to see what was wrong.
Richard
Richard
Paul Baker
Richard
Any other manufacturer would:
1 Not answer until asked many, many times.
2 Tell the customer that such a thing never happened before.
3 Tell the customer to check his wiring, his power supply, his mental state and a few other things.
4 Have no idea what happened.
5 Not offer any help - at least not without asking a bundle for it.
You are really different! And good.
Here are pictures of my Prop-Bot circuitry. The yellow battery pack is a 4-cell NiCd connected directly to the PE supplied 3.3V regulator. Please inform me if you see something I shouldn't be doing.
Richard
Here is another picture with more detail. I used MS Paint as suggested.
Richard
Paul Baker
Thanks for the help, the new chip should arrive shortly. I will be extremely careful about static issues and keep my wiring short.
Richard
Paul Baker
Thanks,Paul
Richard
The attached diagram is an accurate representation of my current layout, but I've had other layouts in the past, and one of them may have fried something.
Post Edited (Bergamot) : 6/14/2007 3:42:51 AM GMT
Paul Baker
Richard
·I will second Richard's comment. I would love to know how you made that breadboard drawning.
Whit+
Mainly because I'm faster in that than anywhere else.
Paul Baker
This is sounding familiar. I know what screwy means.
Richard
I don't think I was careful enough about static protection when I handled the Prop chip. You can bet I will be when the new one arrives. I am fishing for something you and I may have in common. Believe me I know what "acting screwy" means. Have you been running servos? There is a lot of RFI being generated inside those babies and it may be what got to my PLL. I will be using lots of capacitor protection to prevent that in the future.
Richard
Mainly, I just want to locate the problem, and see what I can do to make sure it doesn't happen again. If I need to change my layout, or reorder replacement components, no big deal.
Paul Baker
but with this code it works fine (albeit at only 5mhz, which is fine for my needs as long as nothing else is wrong):
Thanks for the sample. What you're describing is probably the PLL failure that's been noted before. The clock works, but any PLL multiplier prevents the program from working because the clock can't get from the PLL to the HUB. The RC oscillator works and I believe the direct clock input works as you've observed. Others (Chris and Paul) have described this as a failure point when the chip is subjected to voltage spikes or noise beyond its ratings. Good filtering on the power supply lines and rerouting of noisy high-power wiring away from the chip and its connections should help.
I am the originator of this thread and I am going add more confusion to the issue of PLL failure. I rewired and added capacitors and resistors as Paul suggested. Any wiring associated with the servos are several inches away from the chip. I have 100nf caps at each servo connection to the board and at the two 3.3v pins on the chip. I have a 1000uf cap where my battery power enters.
I received my new chip today and was meticulous in preventing static damage (wristband,etc.). I installed the chip on my board and started testing. Here are the results:
LED blink timing test shows 1 second cycle for all clock modes using 5Mhz crystal and using a crystal + PLL..x. My timing is done using waitcn(clkfreq/2 + cnt). This is good news.
Servo test was bad news! Servo positions change significantly with clock modes. Servo RPM for continous rotation servos (bot wheels) changes with clock mode. Timing for pulses is done using the same method as LED blink test. In RCFAST (12Mhz RC osc) servos are stopped with waitcnt(clkfreq/668+cnt), in xtal1 + pll1x a clkfreq/890 stops the servos! For 16x the timing is back to clkfreq/664. x4 and x8 are all different also.
I can press ahead with my projects using a set oscillator speed, but I have a feeling my PLL is going to die again as before. I am not sure what to do. Paul suggested a separate power supply for the servos and chip with a common ground. Maybe that is the answer but to me it is kind of a tomahawk engineering approach.
Appreciate any suggestions,
Richard
Let's rule out coding issues. Attached is some code (Test Two Servos.zip) I tested for holding the center pulse duration on my PEKbot (drives two Parallax Continuous Rotation Servos). I set the I/O pins to P16 and P18 with the help of the pictures you posted earlier. Try it out, and let me know if the center pulse duration still varies when you change the PLL multiplier. It shouldn't unless you use one of the RC modes.
Andy
Andy Lindsay
Education Department
Post Edited (Andy Lindsay (Parallax)) : 6/15/2007 5:40:23 PM GMT
I can't answer for the BS2 library, but you can use spin to control pulse duration with accuracy down to the 80 MHz clock tick (12.5 ns). See the Counter Modules and Circuit Applications PE Kit Lab for details. The Test Two Servos object above is using the approach introduced in that PE Kit Lab. Once I get the comments and variable names adjusted, the modified version of the archive above will become part of that lab.
PE Kit Labs
http://forums.parallax.com/showthread.php?p=617192
http://forums.parallax.com/attachment.php?attachmentid=0
Andy
Andy Lindsay
I ran Test Two Servos.spin. Servos never stop, they run at the same speed (about 20 RPM) regardless of selected pll..x setting. The sweep isn't occuring, not sure I know why.
Richard
p.s. servo pins are 16 and 19
