Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
count command help — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Robotics
count command help
science_geek
247
2007-06-12 02:16
edited 2007-06-12 20:09
in
Robotics
how do i use the count command to add the number of times a switch is hit
and debug the number
Skywalker49
172
2007-06-12 20:09
http://www.parallax.com/dl/docs/prod/stamps/web-BSM-v2.2.pdf
pag 149 .. all you want to know about the count command and connect your switch like this.
It is all in the Parallax documents on their site (free downloads)
+5V
> 10 kOhm
Pin
/ switch switch open = 1, switch closed = 0
__ ground
Good luck,
Ed
Post Edited (Skywalker49) : 6/12/2007 8:17:30 PM GMT
Sign In
Register
to comment.
.················ +5V
.················ > 10 kOhm
Pin
.·················· / switch switch open = 1, switch closed = 0
.·················__ ground
Good luck,
Ed
