Odometer Readings
Needed an idea of how to get the information on an LCD using a BS2, of the cars·mileage.
Regards
Regards
Without knowing how the data is acquired into the BS2 there is no way to know what format you have it in for display on the LCD. How are you recording this information into the BS2?
If it is a newer vehicle then you may be able to get some of the data from that. I believe that some of the on board computers already track mileage and other parameters.
Some data should be available at the diagnostic port. There is at least one place that makes a data logger that connects there:
http://www.davisnet.com/drive/products/carchip.asp
Another interesting thing to get data from is the BlackBox that a lot of new cars have. I found a list that shows some cars with these "black boxes" at:
http://www.komotv.com/news/7299131.html
http://www.harristechnical.com/downloads/cdrlist.pdf
If you can just have the stamp ask the car's computer what the mileage is that would be the easiest method. Otherwise you'll have to try and tap into the existing sensors or add your own.
Good Luck,
Robert
