How do you add multiple binary displays
ok...· I will try to explain this so someone can help me.
Lets say I am using three definied VAR of word value
Digit0·· var word
Digit1·· var word
Digit2·· var word
and I first display the number 100 on the three displays...
Digit0 = $0100··· '· 16-bit word = %0000000100000000
Digit1 = $0200··· '· 16-bit word = %0000001000000000
Digit3 = $0301··· '· 16-bit word = %0000001100000001
The 1,2, and 3 represent each separate 7-segment display
Now I want to subtract 25 from the 100 total to get 75!
the final display setup should be as follows:
Digit0 = $0105··· '· 16-bit word = %0000000100000101
Digit1 = $0207··· '· 16-bit word = %0000001000000111
Digit3 = $0300··· '· 16-bit word = %0000001100000000
Ok...· how do I go from the first display setup to the second display setup?
How do I do the subtraction and keep each of the individual display settings for the 1,2, and 3 displays?
Thanks for the help
Joe
Digit0·· var word
Digit1·· var word
Digit2·· var word
Thanks for the help
Joe
You define Digit0, Digit1 and Digit2, then in all your examples you use Digit0, Digit1 and Digit3. Also, what 1, 2 and 3 are you referring to?
http://forums.parallax.com/showthread.php?p=655350
