Is this normal - PLZ HELP!! — Parallax Forums
computer guycomputer guy Posts: 1,113
edited 2007-06-11 09:22 in Propeller 1
I have just finished attaching the propeller DIP up to my homemade board.
I have a light connected to each regulator via a 1k resistor.
5v-->1k-->led-->GND
3.3v-->1k-->led-->GND
If i connect the propplug up to my board the 3.3v power light comes on.
I have checked all my wiring with a multimeter.
Is this normal?
Check out my robot using the propeller robot.tmcp.com.au
If you offer cheap PCB fabrication, perl programming or any other helpful services please email me at.
anthonybmyatt@yahoo.com.au
  • LeonLeon Posts: 7,620
    edited 2007-06-11 09:06
    This often happens when programmers are attached without a supply being present - enough current sneaks back to the supply though the device pins to light an LED.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
  • computer guycomputer guy Posts: 1,113
    edited 2007-06-11 09:08
    Is there a way to overcome this?
    edited 2007-06-11 09:20
    I don't think so, apart from putting a diode in the supply. It doesn't cause any harm. You could always remove the LED if it bothers you. lol.gif
    Leon
