Help adding and subtracting with the MAX7219 and the Basic Stamp 2
Hello all,
I play steel tip darts and no one makes an electronic·score board without the dart board so...
I am using the MAX7219 chip with the BS2 chip and have come across a problem that hopefully all you out there can help me with!
Example:· Lets say you are playing a game of 401 and need to subtract from this score.
The BS2 chip sends data in the form;
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
to represent a····· 1 in the first 7-segment display
················ a····· 0 in the second 7-segment display
··············· and a 4 in the third·7-segment display.
I can debug the values by useing the following command:
····· DEBUG··· DEC Dig0, " " ,DEC DIG1, " ",DEC DIG2
and this gives me 1 0 4 in the debug window but...
if I use the following;
one = Dig0
ten = Dig1
hundred = Dig2
I dont get any value from these numbers!!!
how do I get the values from these numbers so I can add,subtract, or multiply them????
any thouthts?
thanks in advance
P.S.· Does any one have a program that will add and subtract using the MAX7219 and the BS2?· If so this would save me a lot of time!!!
Oh and by the way... here is the code so far if any one is interested.
I am using the PDBoard with three of the five 7-segment displays and the 8 switches to test the following:
When you hit·one of the eight·buttons you get the following so far:
Cr············ 'for Cricket
P 1··········· 'for player 1
501···········' for a 501 game
401·········· ' for a 410 game
reset········ ' to reset the three displays
the other three are for testing use
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
'0 sets pin as input
'button PIN 0 makes the word button = pin 0
DIRS = $000E············ 'pins 1 2 3 output,all other pins outputs
DOUT PIN 1·············· 'pin 1 of stamp to pin 1 of 7219
Load PIN 2·············· 'pin 2 of stamp to pin 12 of 7219
CLK PIN 3··············· 'pin 3 of stamp to pin 13 of 7219
[noparse][[/noparse] Constants ]
IsLow CON 0
IsHigh CON 1
[noparse][[/noparse] Variables ]
Dig0 VAR Byte
Dig1 VAR Byte
Dig2 VAR Byte
btn·· VAR Bit
Value VAR Nib
total VAR Byte
temp VAR Byte
one VAR Byte
ten VAR Byte
hundred VAR Byte
[noparse][[/noparse] Initialization ]
Dig0 = $010F
Dig1 = $020F
Dig2 = $030F
Value = 0
main:
··· GOSUB DecodeMode
··· GOSUB ShutDownMode
··· GOSUB ScanLimit
··· GOSUB Intensity
··· GOSUB reset
loop1:
· BUTTON 5,0,255,250,btn,1,press
· BUTTON 15,0,255,250,btn,1,press1
· BUTTON 6,0,255,250,btn,1,press2
· BUTTON 4,0,255,250,btn,1,press3
· BUTTON 7,0,255,250,btn,1,press4
· BUTTON 11,0,255,250,btn,1,press5
· BUTTON 12,0,255,250,btn,1,press6
· BUTTON 13,0,255,250,btn,1,press7
· GOTO loop1
· press:············· 'Press button [noparse][[/noparse]1]
· GOSUB DecodeMode
· GOTO Begin_401
· press1:············ 'Press button [noparse][[/noparse]2]
· GOSUB DecodeMode
· GOTO Begin_501
· press2:············ 'Press button [noparse][[/noparse]0]
· GOSUB DecodeMode
· GOTO reset
· press3:············ 'Press button [noparse][[/noparse]7]
· GOSUB DecodeMode
· GOTO Player_1
· press4:············ 'Press button [noparse][[/noparse]3]
· GOTO Cricket
· press5:············ 'Press button [noparse][[/noparse]6]
· GOTO Add_20
· press6:············ 'Press button [noparse][[/noparse]5]
· GOTO Add_19
· press7:············ 'Press button [noparse][[/noparse]4]
· GOTO Subtract_20
[noparse][[/noparse] GOSUB RESET ]
reset:
· Dig0 = $010F
· Dig1 = $020F
· Dig2 = $030F
· GOSUB board_display:
GOTO loop1
[noparse][[/noparse] GOSUB BEGIN_401 ]
Begin_401:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· GOSUB board_display:
··· GOTO loop1
[noparse][[/noparse] GOSUB BEGIN_501 ]
Begin_501:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0305
··· GOTO loop1
[noparse][[/noparse] GOSUB Player_1 ]
Player_1:
··· Dig0 = $0101
··· Dig1 = $020F
··· Dig2 = $030E
··· GOTO loop1
[noparse][[/noparse] GOSUB Cricket ]
Cricket:
··· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0900\16]
· HIGH Load
··· Dig0 = $0100··· 'THIS IS BLANK
··· Dig1 = $0205··· 'THIS IS THE LETTER r
··· Dig2 = $034E··· 'THIS IS THE LETTER C
··· GOTO loop1
[noparse][[/noparse] GOSUB Add_20 ]
Add_20:
··· 'If total is 401 then Add 20 to the total
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0306
··· GOTO loop1
[noparse][[/noparse] GOSUB Add_19 ]
Add_19:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· 'GOSUB hundreds:
··· 'GOSUB tens:
······ DEBUG··· DEC Dig0, " " ,DEC DIG1, " ",DEC DIG2
··· GOTO loop1
[noparse][[/noparse] GOSUB Subtract_20 ]
Subtract_20:
··· 'If total is 401 then subtract 20 from total
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· GOTO loop1
[noparse][[/noparse] Subroutines ]
'Decode mode for no decoding to BCD
'Least sig nibble:
'0 = no decode
'1 = decode digit 0
'F = decode digits 0-3
'FF = decode digits 0-7
DecodeMode:
· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$090F\16]
· HIGH Load
· RETURN
'Set shutdown mode so device is active
ShutDownMode:
· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0C01\16]
· HIGH Load
· RETURN
'Set scan limit mode for three digits
ScanLimit:
· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0B02\16]
· HIGH Load
· RETURN
'Set intensity of LEdDs
'LSNibble 0 = min intensity and F = max intensity
Intensity:
· LOW Load
· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]$0A09\16]
· HIGH Load
· RETURN
board_display:
··· LOW Load
··· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Dig0\16]
··· HIGH Load
··· LOW Load
··· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Dig1\16]
··· HIGH Load
··· LOW Load
··· SHIFTOUT DOUT, CLK, MSBFIRST,[noparse][[/noparse]Dig2\16]
··· HIGH Load
··· PAUSE 400
RETURN
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
one = Dig0
ten = Dig1
hundred = Dig2
any thouthts?
thanks in advance
' {$STAMP BS2}
' {$PBASIC 2.5}
IsLow CON 0
IsHigh CON 1
Dig0 VAR Byte
Dig1 VAR Byte
Dig2 VAR Byte
btn·· VAR Bit
Value VAR Nib
total VAR Byte
temp VAR Byte
one VAR Byte
ten VAR Byte
hundred VAR Byte
Dig0 = $010F
Dig1 = $020F
Dig2 = $030F
Value = 0
main:
··· GOSUB ScanLimit
··· GOSUB Intensity
··· GOSUB reset
loop1:
· GOTO loop1
· GOSUB DecodeMode
· GOTO Begin_401
· GOSUB DecodeMode
· GOTO Begin_501
· GOSUB DecodeMode
· GOTO reset
· GOSUB DecodeMode
· GOTO Player_1
· GOTO Cricket
· GOTO Add_20
· GOTO Add_19
· GOTO Subtract_20
reset:
· Dig0 = $010F
· Dig1 = $020F
· Dig2 = $030F
GOTO loop1
Begin_401:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· GOTO loop1
Begin_501:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0305
··· GOTO loop1
Player_1:
··· Dig0 = $0101
··· Dig1 = $020F
··· Dig2 = $030E
··· GOTO loop1
Cricket:
··· LOW Load
· HIGH Load
··· GOTO loop1
Add_20:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0306
··· GOTO loop1
Add_19:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· 'GOSUB tens:
··· GOTO loop1
Subtract_20:
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
··· GOTO loop1
'Least sig nibble:
'0 = no decode
'1 = decode digit 0
DecodeMode:
· LOW Load
· HIGH Load
· RETURN
ShutDownMode:
· LOW Load
· HIGH Load
· RETURN
ScanLimit:
· LOW Load
· HIGH Load
· RETURN
Intensity:
· LOW Load
· HIGH Load
· RETURN
board_display:
··· LOW Load
··· HIGH Load
··· LOW Load
··· HIGH Load
··· LOW Load
··· HIGH Load
··· PAUSE 400
RETURN
But I noticed that you have Dig0 Dig1 and Dig2 allocated as bytes, but then you make assignments like:
Dig2 = $0304
Since Dig2 is a byte, it becomes $04, and the upper part $03 gets dropped. That is true of all the digN assignments. I don't know what purpose the $03 was supposed to serve. Maybe position, but the pointer was automatically incremented by the '7219.
It might be better to store the score values as a word in decimal so that you can do the math on them, and have a little subroutine that converts the decimal value to a string to send to the display. For example,
score = 401
score = score - 20
dig0 = score dig 0
dig1 = score dig 1
dig2 = score dig 2
Look up dig in the Stamp help. It is a math operator that extracts the decimal digits from a variable.
Tracy Allen
www.emesystems.com
Actually the Dig0, Dig1, and Dig2 are word and not byte.· I guess I had modified the code for a test and posted it before I put it back to normal.
So... a value like $0304 is how the MAX7219 chip displays digits on a 7-segment display...· it is broken down to... 03 for the # of the 7-segment display used and
the 04 is the value shown on the display.
So the values
··· Dig0 = $0101
··· Dig1 = $0200
··· Dig2 = $0304
represents three 7-segment displays and on these three displays is 401
I understand what you are giving me but how do I go from:
· score = 401
· score = score - 20
· dig0 = score dig 0
· dig1 = score dig 1
· dig2 = score dig 2
to...
··· Dig0 = $0101
··· Dig1 = $0208
··· Dig2 = $0303
Joe
score = 401
score = score - 20
dig0 = score dig 0 + $0100
dig1 = score dig 1 + $0200
dig2 = score dig 2 + $0300
Tracy Allen
www.emesystems.com
Worked like a charm!· The problem I was having when I was testing your code was I forgot to change the VAR of score to a word size instead of byte.
Because it was set to byte it wasn't big enought to hold anything over 255 in value and I kept getting odd values!· This was really driving me crazy!
Thanks a bunch.
When I get the whole thing finished I will post it on this site!
Joe
“Intellectual growth should commence at birth and cease only at death”
Albert Einstein
