SXB to C programming — Parallax Forums
djfx1djfx1 Posts: 5
edited 2007-06-08 03:42 in General Discussion
Hi there, I'm new to the group so I'm not sure if this is the right place to post this.··I have some code that was written in SXB and a friend asked if I can convert it to C. I'm not familiar with C but have been trying to start. I was wondering if someone here could possibly help me out.· I am going to post the code:· Thank you in advance for any help provided.
' Device Settings
DEVICE········· SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ··········· 4_000_000
' IO Pins
TX···············VAR·RA.2···' serial to/from host
RX·············· VAR·RA.3
CS·············· VAR·RB.0
Clock··········· VAR·RB.1
Dio··············VAR·RB.2
WATCH Dio, 12, UDEC
' Constants
Baud··CON·"OT9600"
LF············· CON·10
FF············· CON·12
CR············· CON·13
' Variables
adcLo········· VAR·Byte
adcHi··········VAR·Byte
temp1········· VAR·Byte···' subroutine work vars
temp2········· VAR·Byte
temp3········· VAR·Byte
temp4········ ·VAR·Byte
temp5········· VAR·Byte
· PROGRAM Start
CRLF:
· DATA CR, LF, 0
' Subroutine Declarations
WAIT_MS········ SUB·1, 2
TX_BYTE········ SUB·1
TX_STR········· SUB·2
TX_HEX2········ SUB·1
RD_1298········ SUB·1
' Program Code
Start:
· PLP_A = %0000
· PLP_B = %00000111
· PLP_C = %00000000
· HIGH CS················· ' deselect adc
· LOW Clock··············· ' init clock for 0-1-0
Main:
· DO
··· TX_BYTE FF············ ' clear ASCII terminal
··· TX_STR "LTC1298"
··· TX_STR CRLF
··· TX_STR "
··· TX_STR CRLF
··· TX_STR "Ch0: "
··· RD_1298 0··············' read channel 0
··· TX_HEX2 adcHi········· ' display (hex)
··· TX_HEX2 adcLo
··· TX_STR CRLF
··· TX_STR "Ch1: "
··· RD_1298 1··············' read channel 1
··· TX_HEX2 adcLo
··· TX_STR CRLF
··· WAIT_MS 250, 2
· LOOP
· END
' Subroutine Code
' Use: WAIT_MS milliseconds {, multiplier}
' -- multiplier is optional
WAIT_MS:
· temp1 = __PARAM1····························· ' get milliseconds
· IF __PARAMCNT = 1 THEN······················· ' if no multiplier
··· temp2 = 1·································· '·· set to 1
· ELSE········································· ' else
··· temp2 = __PARAM2··························· '·· get multiplier
· ENDIF
· IF temp1 > 0 THEN···························· ' no delay if either 0
··· IF temp2 > 0 THEN
····· PAUSE temp1 * temp2······················ ' do the delay
··· ENDIF
· ENDIF
· RETURN
' Use: TX_BYTE aByte
' -- transmits one byte to serial port
TX_BYTE:
· temp1 = __PARAM1····························· ' copy outgoing byte
· SEROUT TX, Baud, temp1
· RETURN
' Use: TX_STR [noparse][[/noparse] string | label ]
' -- "string" is an embedded literal string
' -- "label" is DATA statement label for stored z-String
TX_STR:
· temp3 = __PARAM1····························· ' get string offset
· temp4 = __PARAM2····························· ' get string base
· DO
··· READ temp4 + temp3, temp5·················· ' read a character
··· IF temp5 = 0 THEN EXIT····················· ' if 0, string complete
··· TX_BYTE temp5··················· ·········· ' send the byte
··· INC temp3·································· ' point to next character
··· temp4 = temp4 + Z·························· ' update base on overflow
· LOOP
· RETURN
' Use: TX_HEX2 aByte
' -- sends "aByte" to host in HEX2 format (text)
TX_HEX2:
· temp2 = __PARAM1····························· ' copy byte
· FOR temp3 = 1 TO 2··························· ' send two nibbles
··· temp4 = temp2 & $F0························ ' get a nibble
··· SWAP temp4
··· IF temp4 < $A THEN
····· temp4 = temp4 + "0"······················ ' convert to "0".."9"
··· ELSE
····· temp4 = temp4 + 55························' convert to "A".."F"
··· ENDIF
··· TX_BYTE temp4······························ ' send to host
··· temp2 = temp2 << 4························· ' position next nibble
· NEXT
· RETURN
' Use: RD_1298 channel
' -- puts ADC value for "channel" (0 or 1) in adcHi\adcLo
RD_1298:
· temp1 = %1011································ ' set for single-ended mode
· temp1.2 = __PARAM1.0··························' select channel
· CS = 0
· SHIFTOUT Dio, Clock, LSBFIRST, temp1\4········' send configuration
· SHIFTIN· Dio, Clock, MSBPOST, adcHi\4·········' get high nib of adc
· SHIFTIN· Dio, Clock, MSBPOST, adcLo\8········ ' get low nib of adc
· CS = 1
· RETURN
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2007-06-07 21:31
    Is the target for the C application the SX chip, or another microcontroller?
    If it is the SX chip, you'll need to state which compiler is being used, since they all work slightly differently in how they handle C syntax.
    If you are targetting a different microcontroller, you would have more success by visiting a forum that targets C on that particular chip.
    Either way, to learn more about C, take a look at my post here:
    http://forums.parallax.com/showthread.php?p=635438
  • djfx1djfx1 Posts: 5
    edited 2007-06-07 21:49
    Thanks Kevin for replying, I believe they also have the SX. I will have to double check.· Would it be possible to give me some pointers.
  • BeanBean Posts: 8,129
    edited 2007-06-07 22:11
    What C compiler are you using (brand name) ?
    Why do you want to convert the program to C ?
    Bean.
    “The United States is a nation of laws -· poorly written and randomly enforced.” - Frank Zappa
    www.hittconsulting.com
    edited 2007-06-07 22:30
    To answer your first question, I would be using Bloodshed Dev-C++.· For the second a friend of mine if could provide them with the code in C.
  • JonnyMacJonnyMac Posts: 9,799
    edited 2007-06-07 23:22
    Does that compiler support embedded processors like the SX?
    edited 2007-06-08 00:40
    I think it is just a windows C compiler.
    djfx1, are you trying to make this code run on a PC ?
    Bean.
    edited 2007-06-08 01:21
    Im not. My friend was just wondering if I could write it in C. Im not sure what they want to use it on.
  • John R.John R. Posts: 1,376
    edited 2007-06-08 01:56
    I'd say that based on what the program is doing: displaying the data from the "1298" device on a "host" terminal, finding out what they are going to run the software on is the first step.
    If they are going to run it on a PC, 80% of the program would need to be re-written, as most of the program is written to send the labels and data to a terminal. This hardly makes sense if the software will be running on a PC (you'd use the PC display screen, and assumedly, some type of windows form).
    If they are using another type of microprocessor, then you'd need to know how that processor (and C compiler) handled the communications for the terminal (asynchronous) and the "1298" device (synchronous).
    I don't think the way to approach this would be a "line by line" conversion, but rather a "re-write" based on the specific tool used.
    John R.
    Click here to see my Nomad Build Log
    okay thx
